Anybody here have one of those indoor lap pools where you swim against the jets? Something that can fit in the basement.
If so any local companies that supply them and rough cost?
No idea but consider the humidity issues; you'll need to have blue drywall (waterproof stuff) and proper ventilation.
Swim Spa is what they're called i think, my freind's sell them at sun spa on blackfoot
Do you have to reinforce the floor? I think you’re probably looking at a total of 5000lbs ish over a small areas, would that require modifications?
Called sun spa. Start at $33k and would need a concrete pad as they are heavy. Can’t go in basement as it needs to be craned in unless house just had foundation poured and nothing else. Still think that’s not bad. Fk some cars run $30k in options. Haha
Could just build an insulated enclosure outside? haha i didn't really think of that though, how would you even get one in a house..This quote is hidden because you are ignoring this member. Show Quote
Paradise Spas has some giant outside ones.. some were up to $50k!
There's also called Endless Pools. That's the one Lionel Sanders uses. Those are around same price, start around $20k USD.
