LED Light Bulb Interfering with Garage Door Opener? - Beyond.ca - Car Forums
Results 1 to 20 of 28
Thread: LED Light Bulb Interfering with Garage Door Opener?
    Apr 2004
    Default LED Light Bulb Interfering with Garage Door Opener?
    So the past few weeks my Chamberlain garage door opener has been quite finicky. Works intermittently, and most of the time i have to slide the opener button off the visor and move around in the car or even reverse back and forth until i can find a sweet spot to catch the signal. As you can imagine this is a major piss off when you back out of the garage trying to leave your house. I had it completely chalked up as a failed receiver logic board, so this morning was searching around where i could find a replacement receiver board instead of changing out the whole opener. As i was looking around, came across this youtube video:
    Then it dawned on me.... a few weeks ago the light burnt out, and i popped two new LED light bulbs in and that's right around when it started acting up. I did kind of correlate the timing, but i figured i might have bumped the board or something while i was changing the bulb. never would i have imagined the bulbs themselves interfering with the signal.
    Tonight i'm going to try and find some incandescent lights to use in there instead of LEDs (hope i can find an old one or buy one somewhere) and crossing fingers this will fix the problem.
    anyways, wanted to share this in case anyone else runs into this problem before they rip their hair out. also curious if this has actually happened to anyone else? Funny thing is there is nothing on Chamberlain's troubleshooting website that i could find about it... very lucky to have come across that youtube video otherwise i'd have wasted my time swapping out the receiver logic board.
    Let us know if that fixes your issue. It's a good tip.
    The SHBARUS
    Slightly related regarding the signal to control the garage door opener, it was chamberlain as well.
    Last year when I was setting up the myq for my old garage door opener I couldn’t get them to pair for whatever reason. I was almost at the point to give up. Took the myq down from the ceiling and tried again one last time and it worked. Apparently I had the thing too close to the garage door opener. I did follow the instruction and it shows the recommended distance, it’s still too close I guess. Finally installed it may be a foot away and it’s good. If anyone runs into similar problem, that may be the cause.
    Sep 2007
    golfR
    The manual of my chamberlain specifically says do not use LED light bulbs as it can interfere with with signals.
    Not a guarantee but it can happen.
    Dec 2008
    Very interesting, apparently the drivers on some LED bulbs emit electromagnetic interference. I would try going to a more expensive bulb if it’s a cheapo. I replaced mine with Feits I believe and haven’t had any issues.
    N/A
    Incandescents are still available, they're just called heavy duty or rough duty or such to get around the rules.
    Will fuck off, again.
    Beaumont
    Touareg, Cayenne, 944s
    I've had this happen. It's especially bad with dimmer LEDs. I replaced an incandescent bulb in a lamp with a dimmable LED right above the garage in the bonus room and had no end of trouble with the remotes until going back to a regular bulb. It seems especially bad when the dimmer is on the lowest setting and the light seems off, but it's still getting a small voltage.
    Sep 2006
    Secret City, Alberta
    2018 Civic Si coupe
    I have a CFL bulb in mine, zero issues, but those are getting hard to find too. I was thinking of replacing it with an LED bulb but not anymore thanks to this
    Apr 2004
    Edmonton
    2020 Genesis G70
    Great post! One of the bulbs in my garage door just burnt out and I was planning on replacing both with LED. Looks like I will stay old school now. Thanks for saving a major headache!
    Apr 2004
    Brand is philips so would think they are decent quality.
    Anyways, Home Depot has a very small collection of incandescents. Grabbed a 2 pack that is specifically marketed for garage door openers (vibration-resistant) for about $6 and threw em on. So far so good, remote button worked first try as it should.
    Dec 2008
    I double checked today, bulb I’m running in mine is a feit 60w equivalent (part number 280-16-28). Garage door opener is a linear, bulb is on the front antenna sticks up from the rear. Zero issues (been running it for a year)
    Jul 2008
    Pallet Town
    They also still sell appliance rated bulbs. You can't put a LED or CFL in an oven.
    Cocoa $11,000 per tonne.
    Quote Originally Posted by ZenOps View Post
    don't tell me what I can't do!
    Nov 2003
    Cowtown
    N54B30O1
    I recently had LED christmas lights put up and now my garage door openers only work at very close range -- i.e. 10-20' from the door, versus 150' away before. FWIW.
    Elbonia
    Jeep of Theseus
    I just installed 10 of the T8 LED bulbs in my shop and discovered the same issue - no door remotes work if the lights are on.
    I consider this a feature, not a bug - now nobody can randomly open the door while I'm working and let the warm air out!
    Cochrane, AB
    Trucks
    What I’m taking from this thread is never buy a POS Chamberlain door opener. Talk about a failure in engineering.
    I also had issue with my garage opener range as well, did a bunch of research on it as I literally had to be on the pad to open garage door. Also had LED bulb, I flipped back to CFL but didn't notice much difference so kept LED. I thought maybe my neighbours had some wifi device interfering with signals. I checked my wifi device but nothing changed. I even had my homelink replaced on my Mercedes thinking it was faulty (they swapped the whole mirror). I found a youtube vid of extending the garage opener antenna https://youtu.be/ZrIMhHTW0kk
    I decided to try that myself and it made a huge difference. I had some spare speaker wire so used that instead as extension. You can see in my pic I looped it around in the front of garage above garage door.
    Name:  Annotation 2018-12-09 110919.jpg
    I installed the Chamberlain MyQ garage opener after my wire extension. I was a little apprehensive initially about purchasing it as it might mess with my range again but my paranoia of not closing the garage door at night or driving away got the better of me.. so far range has not been affected. I never did find the root cause of why my range suck but just glad it's resolved as it drove me nuts when the issue occurred.
    Sep 2002
    BoostLand
    something green
    Unfortunately they make a lot of the different door openers. I have the commercial grade liftmasters in my garage, and even they fell victim to LED interference. I was up on my extension ladder for 2 hours one night trying to get the remotes tied to the openers with no luck. The next day I went out to try again, and it all worked, the only difference was all the lighting was turned off in the garage.
    Here is a list of approved bulbs.
    https://www.garaga.com/ca/blog/which...ge-door-opener
    Too loud for Aspen
    Dec 2008
    I have 4 LED bars pretty close to my opener and no issues?
    ^this, I was going to ‘upgrade’ to a chamberlain smart opener. Guess not!! I’ll stick with my linear
    Elbonia
    Jeep of Theseus
    I have a Chamberlain opener, and they seem to be more affected by LEDs than other openers. Your non-Chamberlain opener may not be affected the same way.
  1. Raising my garage door- garage door advice
    By craigcd in forum Home and Garden
    Latest Threads: 04-01-2018, 09:17 AM
  2. Replies: 3
    Latest Threads: 02-25-2018, 05:54 PM
  3. is discussing your new job w/ old co-worker consider interfering,enticing,soliciting?
    By jmc in forum Society / Law / Current Events / Politics
    Latest Threads: 08-13-2014, 03:34 PM
  4. HID's Interfering with Satelite radio?
    By CelicaST-162 in forum In Car Entertainment / Electronics
    Latest Threads: 10-27-2007, 11:57 PM
  5. Remote Start Transmitter Interfering with Factory Transmitter?!
    By Davetronz in forum In Car Entertainment / Electronics
    Latest Threads: 11-09-2003, 09:59 PM
