Best way to remove Plastidip from entire car - Beyond.ca - Car Forums
Results 1 to 9 of 9
Thread: Best way to remove Plastidip from entire car
    Aug 2008
    Medicine Hat
    Default Best way to remove Plastidip from entire car
    So I bought a car last night, its a MKIV GTI VR6 24V. kind of an impulse buy, car is in great shape inside, and mechanically very sound. EX BC car so rust is almost non existent....however...the entire car is plastidipped, front to back top to bottom. I am told its quite scratched underneath as a PO keyed his own car to try and scam a new paint job (or so I am told), and was denied. The guy I bought it from was the one who sprayed it with dip, and it doesn't look to great. What would be my best way to remove it from the entire car, thought maybe pressure washer? I know it peels easy, but not sure about a whole car. Ive only done small jobs like removing it from wheels or a bumper.
    My plan is to remove it all, and get a better look at the paint, might be able to clean it up quite a bit with some polish and sanding work. Car was cheap enough, but not cheap enough to re-paint Id like to restore it as best I can, always loved the MK4 GTI, and being a 24V is a big plus!
    Aug 2004
    Edmonton/Calgary
    This and that.
    I think there is some kind of a spray that you can get that is designed to remove this stuff. Not sure what it is called. Goo Gone might work too but I guess you'd need it in larger quantities. I would honestly just attack it panel by panel by applying some heat and going to town on it. There isn't going to be any quick and easy way per se.
    Sep 2008
    NE
    Ram 1500, '68 Camaro, S14
    i always figured when i wanted to get it off my rims id just peel a tiny bit off and then hammer down with a pressure washer...... i think it depends on the thickness, if it's thick it would peel, if not it'll come off in chunks like my first attempt at doing some rims haha..
    Let us know what you figure out though, interested.
    '14 Taco
    The 'black wet tire shine' stuff and WD40 makes it melt.. so go to town with that, wait 5 min, pressure wash to finish it off..?
    Aug 2008
    Medicine Hat
    hmm...that's a good idea, ill see how it goes. He said its about 3 coats, so pretty thin. I usually do wheels in 4-5 coats or more.
    Aug 2008
    Medicine Hat
    Well I needed to wash it last night, so I wanted to see how easy the dip would come off....now its a giant mess haha. I don't plan on driving it anytime soon, so that's a plus, but it will definitely need the Goo-Gone treatment, and a lot of water pressure and patience. ill throw some pics up when I start a build on it, but the one fender I got clean is certainly keyed, and has some kind of debris all over it (picks off with your finger).
    This may be a lot more work than I first thought, but figured it was worth saving, or at least trying my hand at it.
    Careful on goo gone and other stuff around the plastic trip pieces and the taillights. It'll melt or disfigure those.
    V8s
    What about one of those rubber eraser wheels that you put on a drill? They work great for taking glue/residue off, I'm positive it would take off the plastidip and whatever shit is underneath that you can get with your fingernail. Haven't used one on an entire car before, but used in small areas and they work like a charm.
    edit:
    https://www.princessauto.com/en/deta...el/A-p8570970e
    Aug 2008
    Medicine Hat
    Spent 4 hours last night peeling off everything I could by hand. I tried a panel with goo gone and it works pretty well, but makes a mess smearing the dip. Going to soak it tonight and hit it with the pressure washer. Makes me never want to see a can of this shit again..
  1. Plastidip 6 to 12 months later?
    By BensonTT in forum Car Care, Detailing and Body Work
    Latest Threads: 04-27-2012, 10:24 PM
  2. Easy way to paint your wheels (The Plastidip Method)
    By gruster in forum Wheel and Tire Discussion
    Latest Threads: 12-22-2010, 12:48 PM
  3. Best way to remove creases on very thin aluminum?
    By Graham_A_M in forum General
    Latest Threads: 01-08-2009, 07:22 PM
  4. best way to remove street paint
    By the-240sx-guy in forum General
    Latest Threads: 07-18-2006, 08:42 PM
  5. Best way to remove wax from mudflaps?
    By FiveFreshFish in forum General Car/Bike Talk
    Latest Threads: 06-26-2003, 11:27 PM
