Car sitting higher on one side after jacking it up - Beyond.ca - Car Forums
Results 1 to 7 of 7
Thread: Car sitting higher on one side after jacking it up
    Aug 2008
    Medicine Hat
    Default Car sitting higher on one side after jacking it up
    So I started tearing into my project MK4 GTI and ran into an issue. The car has Eibach Pro System with Dampers and springs. I lifted it up one the left side front and back yesterday to look at what size the wheel spacers are. When I put the car back down it sits higher on the left side now. I can fit just under 2 fingers in the right side wheel (rear) well above the tire, but more than 3 on the left side (rear). Everything looks fine, cant see how this happened. Also not sure if this is related but when I took the rear wheel off there was no hubcentric ring in it, so it didn't line up properly going on. I picked up a set of rings this morning and will be putting them on asap, but figured maybe this is something else?
    Have you moved it since you had it up in the air? with transmission in gear or park, and/or e-brake on, it can hold some torque in the system that can load the suspension. If it's not that, I have no idea.
    Aug 2008
    Medicine Hat
    I have not..good idea! I tried putting weight on it but didn't help. I will try that, thanks!
    Aug 2002
    992 T-hawk Golf R
    Completely normal. Drive it around the block, the suspension will resettle, and ride height will be back to where it should be.
    I like neat cars.
    Aug 2008
    Medicine Hat
    Turns out that's the issue...odd I cant recall ever noticing this before, maybe didn't care to.
    thanks for the help!
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    If no helper springs the coils may not be seated in the perches... drive down a couple bumpy roads and you might hear a “BANG!” ...then it will be back to normal
    Jul 2006
    NA
  1. wtb:240sx 1990 or higher,prelude 92 or higher,91 mr2 or higher,
    By gnarkill in forum Cars, Trucks, Motorbikes, and Trailers
    Latest Threads: 03-16-2009, 08:26 PM
  2. hard start-after long sitting time.
    By puggers in forum Mechanical
    Latest Threads: 12-19-2007, 10:21 AM
  3. Starting car after sitting for a year.
    By Xantis in forum Mechanical
    Latest Threads: 08-27-2004, 01:17 AM
  4. 95 Pathfinder won't start after sitting in hot sun
    By drewster in forum Mechanical
    Latest Threads: 06-18-2004, 01:29 PM
