Ford cannot fix engine after repeated attempts. Is there any recourse? - Beyond.ca - Car Forums
Results 1 to 20 of 30
Thread: Ford cannot fix engine after repeated attempts. Is there any recourse?
    Oct 2007
    YEG
    Lotus and a Honda.
    Default Ford cannot fix engine after repeated attempts. Is there any recourse?
    Posting for a friend going through a weird situation, heres the story.
    2014 ford f150 130,000kms starts acting up and has loss of power.
    He takes it into ford dealership, dealership phones back says $3700 for cam phasers and a couple other bigger parts. He gives them the go ahead to fix.
    Picks truck up, seems to run better. Week later same thing. Brings it back in and apperantly one of the cam phasers is acting up again, all good cause it under warranty.
    Week and a half later brings us to today, ford calls and now a compression test shows that the engine is shot. Wtf.
    This sounds off to me like how did these professionals now know this the first time it was in.
    Cost of engine replacement is 12k, and they will subtract the $3700 from previous repair, off the total amount bringing it to just under 9k.
    Got a quote from another smaller auto shop for $6k engine and labour.
    So either way hes fucked. And out the previous 4k of he takes it off the lot.
    Is there any recourse? Or is this how she goes. Could this not have been diagnosed in the first place?
    Jul 2008
    Edmonton, Alberta
    what engine?
    Aug 2008
    Medicine Hat
    Guessing 5.0, never heard of that in the ecoboost. Sounds like they either missed the Diag, or fucked it up. Don't know if contacting Ford would help, but worth a quick phone call. Dealer probably wont back down
    Oct 2007
    YEG
    Lotus and a Honda.
    Quote Originally Posted by ShermanEF9 View Post
    what engine?
    3.5L turbo
    - - - Updated - - -
    Quote Originally Posted by Skrilla View Post
    This is the vibe I'm getting. I just dont think it's fair hes out 4k for nothing? All was fine now the engine is gone?
    Jul 2008
    Edmonton, Alberta
    could be the timing is out now?
    Mar 2009
    Silverado
    I'm sure they did this but apparently oil pressure is important for the cam phaser phase change. So if his oil pump is acting up it could be causing the issues.
    If it is usually a warm or cold issue it could be due to the viscosity change in the oil. Also if the oil channels in the block are fouled it could be starving the phasers.
    Nvm.. that's all for the 5.4 triton
    Sep 2018
    Edmonton, Alberta
    I would consider getting a second opinion. Who is to say if they even did a compression test correctly? If the cam phasers were acting up and the valves weren't seating correctly then you'll definitely fail a compression test.
    Nope - I know some who went through something similar (expensive dealer repairs that were moot in the end) and just ended up selling the thing.
    Never ever use dealers for mechanical work out of warranty - unless is something electronic (ECU flash) or recall,. They just dont give a fuck. This has been demonstrated here time and time again.
    Aug 2008
    Medicine Hat
    Quote Originally Posted by sikid111 View Post
    3.5L turbo
    - - - Updated - - -
    Wow, can't say I have heard of this on the 3.5. Crazy, is a 2014 still a Gen1 Ecoboost, or did they change that year? Cant remember if it was 2014 or 15. Either way, this sounds like it is going to be a headache.
    X5D, Fiesta ST
    I have heard and seen this first hand a couple times. I think another member here had to do the chain and phasers on his Gen 1 as well. Last one I saw with issues had a shade under 130k km.
    Not Aspen
    Two from Freemont
    Gen I. Gen II didn't show up until 2017.
    Oct 2007
    YEG
    Lotus and a Honda.
    Thanks for the responses. Looks like the stealership will win again.
    Hes having it towed out and to the shop that will do it for $6k. Weve ran all the scenarios and fixing it seems to be the best outcome.
    Jul 2008
    Edmonton, Alberta
    Quote Originally Posted by Twin_Cam_Turbo View Post
    It was pretty common for a while. Mine was done at around 70k on my old truck.
    Sep 2002
    CGY
    Cayman, F150, Crosstour
    Same. Mine was done at 90k on my old truck
    May 2004
    CBR 929
    Timing chain, phasers and turbos are all well known issues on the ecoboost, and very very expensive ones too boot. There are so many issues with the timing chains rumor is there will be a recall but hasn't happened yet.
    [url]
    Sep 2018
    Edmonton, Alberta
    Quote Originally Posted by bignerd View Post
    Timing chains seem to be a problem with a lot of Ford built engines. Range Rover ran the Ford V8 for awhile and it was nothing but headaches. All the more reason that friends don't let friends buy Fords.
    4k at dealer plus 6k private puts you at 10k - the dealer was quoting you 9k
    I might have knocked off 1k from pricing - or some other incentive perhaps like lifetime service - and (in this case) stayed with the dealer.
    My earlier piece was regarding the initial visit.
    Oct 2007
    YEG
    Lotus and a Honda.
    Hes getting it for 5k installed through a buddy's shop. He tried talking with service to see if they would budge. Nope.
    The question is, assuming your friend will keep the truck for a while, how to prevent this from happening again? Does the new/rebuilt engine have the mods in place already?
    Oct 2007
    YEG
    Lotus and a Honda.
    I think hes done with "no warranty" vehicles and hes already shopping around. So I'm going to assume itll be sold shortly after he gets it back.
    They're buying a f150 from the auction with 100-130,000kms. Could take up to a month to find.
  1. WIKILEAKS - Israel LIED about repeated Bombings of UN facilities.
    By Toma in forum Society / Law / Current Events / Politics
    Latest Threads: 08-08-2014, 06:50 AM
  2. Got owned by CPA, easiest recourse?
    By Mitsu3000gt in forum Society / Law / Current Events / Politics
    Latest Threads: 04-11-2014, 12:21 PM
  3. Any recourse at all?
    By FraserB in forum General Car/Bike Talk
    Latest Threads: 08-31-2010, 11:52 PM
  4. Olympic ads repeated ad nauseam, but some viewers find beavers 'cute'
    By Foz in forum Society / Law / Current Events / Politics
    Latest Threads: 02-28-2006, 11:56 PM
