Vehicle Details
Year : 2006
Make and Model : Suzuki GSXR 1000
Exterior Color : Black/Grey
Interior Color :
Auto or Manual? : Manual
Odometer Reading : 18,899
Location of Vehicle : Calgary
Description :
Extras :
Asking Price : SOLD!
Selling a mint condition 2006 Suzuki GSXR 1000 as I am no longer riding enough to keep it after 8 years of ownership. This is in my opinion, the best year of the GSXR 1000 as 2007 brought new emissions laws which added weight to the bike and robbed some power. It is an extremely powerful machine and I would highly recommend to only consider purchasing if you are a more experienced rider. I purchased the bike almost new and have been the only rider since that time. It currently has 18,899km on it, which I have done the majority of. It has not been in any kind of accident or even dropped in a parking lot. Active title and currently registered and insured in Alberta.
Bike is now out of storage for the summer and ready for a new owner!
It includes the following:
• Bike currently sits on newer Michelin Pilot Power tires with plenty of life left, factory sizing
• Motovation Frame Sliders
• Anodized red spools for rear stand and stand
• Red key and factory black key
• OEM rear seat cowl with storage below
• Passenger seat
• Passenger seat pegs (removed but can be reinstalled. I don’t ride with passengers)
• Leo Vince SBK carbon fiber exhaust with a carbon fiber hanger, sounds amazing
• Renthal grips
• 1/6 quick turn throttle
• FP Racing adjustable levers, black with red dial
• Fender eliminator in the rear (may be able to find the stock fender but no promises)
• Newer brakes and brake recall from Suzuki is complete
• Oil changed prior to going into storage and always ran OEM Suzuki filters with full synthetic
• LED marker lights
• HID headlight kit which was never installed
• Can include the chain wax cans that I have
• Have a Dianiese one piece suit and alpinestars gloves that could also be purchased which matches the bike as well as an older helmet which is good for occasional use.
• Aftermarket clip-ons
• Aftermarket Windscreen, taller than stock with anodized red screws securing it
• Probably some other things that I am forgetting. She usually gets a couple presents every season
Factory Specifications
Engine: 998.6cc, 4-stroke, four-cylinder, liquid-cooled, DOHC, 16-valve, TSCC
Bore Stroke: 73.4 x 59.0mm
Compression Ratio: 12.5:1
Fuel System: Fuel Injection
Lubrication: Wet Sump
Ignition: Digital/transistorized
Transmission: 6-speed, constant mesh
Final Drive: #530 chain
Overall Length: 2030mm (80.0 in.)
Overall Width: 710mm (28.0 in.)
Overall Height: 1130mm (44.5 in.)
Seat Height: 810mm (31.9 in.)
Ground Clearance: 130mm (5.1 in.)
Wheelbase: 1405mm (55.3 in.)
Dry Weight: 166 kg (365 lbs.)
Suspension Front: Inverted telescopic, coil spring, fully adjustable spring preload, compression and rebound damping
Suspension Rear: Link-type, gas/oil-damped, fully adjustable spring preload, compression and rebound damping
Brakes Front: Dual hydraulic disc
Brakes Rear: Single hydraulic disc
Tires Front: 120/70-ZR-17
Tires Rear: 190/50-ZR-17
Fuel Tank Capacity: 18 liter (4.8 gal.)
Color: Blue/White, Silver/Gray, Red/Black
