Key won't go fully into ignition - Beyond.ca - Car Forums
Results 1 to 7 of 7
Thread: Key won't go fully into ignition
    Oct 2008
    Default Key won't go fully into ignition
    Hi Everyone,
    I have a 2015 Honda civic LX 4dr sedan, manual transmission.
    I've been having this issue where I try to put in the key and it just doesn't go fully in the ignition. The key goes in a little and get stuck. This is the correct key. I fiddle with it several times, trying to turn the wheel, and I keep trying to push in and out and then once out, I put it back in. After fiddling for at least 5 mins, it finally lets the key in and lets me turn the car on.
    I have two keys with fob that this is having an issue with. Surprisingly, the valet key is not having this issue. The valet key slides in like a normal key, and has no issues. I'm not sure what's going on or how to fix. Please help!!
    Mar 2005
    Pushbroom
    An LX Civic comes with a valet key?
    Sep 2018
    Edmonton, Alberta
    Not there to see it myself, but based on your description it sounds like your key is getting worn out. Just seems weird that it would be both keys, unless they both get used pretty equally?
    I do find this somewhat common with older Hondas, but a 2015 seems unlikely unless it has a ton of city miles on it already. Your car probably has a fob so you don't use the key in the door locks ever. You could try the door locks to see if they give you issues as well.
    Does a 2015 not still have warranty?
    Apr 2006
    Sounds like a stuck tumbler. Get some dry graphite powder or spray and put some in the cylinder. Don't use a spray lube, they will gum up the cylinder and then you will need to replace it. Work the key in and out a few times to work the lube in and see if that works.
    '08.5 Mazda 3
    '90 Laser RS-T
    '07 Yamaha R6
    Oct 2008
    Quote Originally Posted by HHURICANE1 View Post
    Ok so you mentioned graphite spray... Is this what you mean? https://www.canadiantire.ca/en/pdp/j...1502p.html#srp
    Or is it something else? I will give it a try asap cuz this is super annoying!
    N/A
    Ummm...
    Will fuck off, again.
    Apr 2006
    https://www.canadiantire.ca/en/pdp/p...0805p.html#srp
    This is what you are looking for.
    '08.5 Mazda 3
    '90 Laser RS-T
    '07 Yamaha R6
  1. Civic-Steering wheel won't unlock, key won't turn.
    By Seth1968 in forum Mechanical
    Latest Threads: 11-20-2010, 05:09 PM
  2. wtb: ignition cylinder and key 99 civic
    By G-ZUS in forum Automotive Parts
    Latest Threads: 05-02-2008, 11:17 PM
  3. key broke in ignition.!
    By Khalil in forum Mechanical
    Latest Threads: 02-13-2005, 04:12 PM
  4. key will not go into ignition
    By Kellys stuck in forum Mechanical
    Latest Threads: 11-17-2004, 02:48 PM
  5. Key will not release from ignition, need some help.
    By jinexile in forum Mechanical
    Latest Threads: 10-30-2004, 04:13 PM
