Hankook Visual Alignment Indicator (VAI) - Beyond.ca - Car Forums
Results 1 to 4 of 4
Thread: Hankook Visual Alignment Indicator (VAI)
    Default Hankook Visual Alignment Indicator (VAI)
    I have tires with this V.A.I. system and I don't know how to use it. I've looked reasonably on Google & YouTube but I can't find anything that explains it. It looks like Continental has a VAI system as well but I doubt it's the same. So much of anything to do with Hankook isn't in English, either.
    Can anyone help? Any tire experts that are familiar with Hankook VAI?
    Jan 2014
    Airdrie
    '16 WRX, '23 CX-50
    Took 30 seconds of googling....
    Video is for Conti's system, they have a better page here that outlines how the system works. Looks like Hankook only has the two dots on the shoulders, but it should work similarly.
    Oct 2008
    South of Calgary
    is broken
    The only tread wear indicator you need.
    Yes, I had also found that video in even less than 30 seconds. I didn't post it because it's for (as mentioned in the original post) a different brand as well as focused on semi-tractor/trailer tires. I have neither of those things.
    While Hankook is "two dots" they are slightly offset from each other and there appear to be additional pairs of dots that are a bit past the outer tread almost climbing up the sidewall.
    Again, if there a member who sells or has experience with Hankook tires, I'd like to learn more.
    Thanks!
  1. Precision Alignment & Brake LTD. - Best Calgary Alignment Shop
    By Commanderwiggin in forum Alberta BMW Owners Club
    Latest Threads: 08-09-2013, 10:24 AM
  2. Steve Vai is a bigger douche than all
    By kerry in forum Entertainment
    Latest Threads: 10-19-2008, 04:20 PM
  3. steve vai shreds
    By googe in forum Entertainment
    Latest Threads: 03-21-2008, 09:33 AM
  4. Palm m515 battery indicator question
    By Daxin in forum Computers, Consoles, and other Electronics
    Latest Threads: 03-14-2004, 12:43 AM
  5. Reset The "Maintenance required Indicator"
    By No.not.again in forum Mechanical
    Latest Threads: 01-20-2003, 01:03 PM
