Adding Windows to Existing Garage Door? - Beyond.ca - Car Forums
Results 1 to 19 of 19
Thread: Adding Windows to Existing Garage Door?
    Oct 2002
    B7 S4, B6 A4, ZX-10R
    Default Adding Windows to Existing Garage Door?
    Has anyone ever added windows to their garage door? I would love to add a row of windows along the top of my door to let extra light inside. I'm having a hard time finding anywhere to buy them though. Anyone have any experience doing this? I know adding any weight to the door means that the spring tension will have to be re-adjusted.
    You just need to get a new row that has windows and replace the one you have now.
    FB6
    You basically try to find a matching panel with windows and replace the top panel of the garage door.
    Nov 2004
    edmonton
    Ford
    i backed into my new garage door with tailgate down. dented one panel in one row. I would like to remove the panel. (2nd from bottom) move everything down and put windows in the top panel. Easy breazzy right?
    Street Tune
    Sep 2005
    Action Door Services Ltd [http://www.actiondoorltd.com/] replaced a door panel for us a few years back. They originally installed the door for the builder, so it was an easy choice.
    Bunch of Honda's
    Action Door let us borrow some samples when we were building, they installed our o/h door and have been out once to service it; they've been awesome.
    Oct 2002
    Ok that sounds like a good option. Any idea on approximate cost? I'll contact them too, just wondering.
    calgary AB
    toyota MR2
    Following. I’d like to know what they tell you.
    I'm not sure I would want people to be able to look in and see my shit. I got some LED panel lights from Costco for cheap that work great to light up my work area...
    dv/dt
    Bunch of Honda's
    You can get frosted glass inserts or have a film added.
    The added natural light is nice but we passed on the windows because they leak so much heat and create a lot of icing issues in the winter.
    Not to mention the incredible safety risk by adding easy access to the safety cord with a simple rock and coat hanger.
    calgary ab
    4x4
    Try it sometime, if you can do it, you're a better man than I am and the doors not installed right.
    Oops.
    Most door companies will sell you a new 500$+ panel with glass and swap it for another couple hundred. About the only person who would cut them in onsite was me. Having watched several companies pull panels recently to change the inserts on the windows - I expect nothing's changed there. (Inserts are called inserts for a reason)
    Calgmonton/AB
    I have the glass panels and it sucks. The garage gets hella-hot in the summer and frosts up like a mother fucker in the winter. I have an 8' door so I'm not as worried about people peaking in and my opener has an auto dead bolt so it's not really a security risk but it still sucks. I have been meaning to tint or get some frosting which should help but it's still a drawback and something to consider.
    ^Same here. In winter, there's constant condensation on ours. The builder only put in single glazed windows, not sure if double glazed would be that much better.
    Although the natural light is nice, I say the effort and cost isn't worth it. The Costco LED shop lights have a motion sensor built in now.
    2020 Subaru Forester Sport
    When I was building my garage I ordered a garage package and built the whole garage as per instructions, forgetting to account for the 1 foot curb wall, so when I went to install my garage door, it was 1 foot short...felt like an idiot. Returned the door and ordered another one with glass inserts. I do like them a lot, my garage is the only one that has them, and my garage is facing the back alley. It does allow a ton of light in so I like it, and the garage door is high, so can't see inside, but I don't live in the hood, so it's pretty safe anyways. It's true that in winter there is lots of frost around them from all the moisture from melting snow, but I don't know, doesn't bother me, I think the positives outweigh the negatives.
    Foothills County
    is faster than yours
    Those of you with condensation on the windows, is your garage heated?
    Calgmonton/AB
    Yes. Only to about 10degC.
    Jun 2007
    '16 ATS4 2.0T
    Just had my entire garage door, track, opener, everything replaced yesterday. Old door had windows, and I got the new door with windows. Love the light that comes in. The garage isn't insulated or heated, so of course I noticed a bit of frost in the winter but nothing that bothered me.
    The only issue now is that the new door's windows are so damned clean it looks like there's nothing in the holes. Once get they get a little dirtied up it'll be back to normal!
    A five-cent ziptie solves that problem. Just snip it if you need to use the manual opener.
  1. Raising my garage door- garage door advice
    By craigcd in forum Home and Garden
    Latest Threads: 04-01-2018, 09:17 AM
  2. Garage door rubber seal between parts of the door
    By nzwasp in forum Home and Garden
    Latest Threads: 11-05-2017, 11:03 PM
  3. Auto insurance question..Adding Wife to Existing policy?
    By eblend in forum Society / Law / Current Events / Politics
    Latest Threads: 04-11-2012, 05:46 PM
  4. Free: Overhead Door CodeDodger ACSCTO Type 1 Garage door remote
    By Zero102 in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 12-20-2009, 04:47 PM
  5. FS: ek parts, hood, gas door, bumper, door windows, etc...
    By ekguy in forum Automotive Parts [Aero/Styling/Interior]
    Latest Threads: 07-25-2008, 12:26 AM
