2009 Dodge Journey - Electrical Advice Needed - Beyond.ca - Car Forums
Results 1 to 8 of 8
Thread: 2009 Dodge Journey - Electrical Advice Needed
    Mar 2006
    Default 2009 Dodge Journey - Electrical Advice Needed
    A few weeks ago on the wife's Journey the windshield wipers quit working. She was wiping snow off the windshield one day and they just stopped working all together. To date i have done the following:
    Replaced the blown fuse
    Test the wipers - did not work
    Tested for power at the motor. 12v constant on 1/5 pins but nothing else regardless of switch position
    Replaced the wiper motor
    Replaced the stalk/Switch
    Test the wipers - still did not work
    At this point i gave up and sent it to my mechanic. It was diagnosed as the TIPM, apparently these are fairly common in the Dodge world to fail. The majority of the circuits in the Journey run through this control board, so this was a logical point of failure. These boards were 1000.00 to replace from Dodge in town so i opted to send it to these guys in the US that came well reviewed - https://circuitboardmedics.com/. They replace the failed circuits/test everything and ship it back, sounds great.
    Apparently the TIPM as tested by Circuit Board Medics is working fine. And i have a new switch and new motor already installed. WTF else could be wrong in such a small circuit?? I am very much at my wits end with something i assumed to be an easy fix. Any help is appreciated on this one.
    Feb 2009
    Saab 9-5
    being a used car tech went thru the same bullshit. Then i disconnected the battery did a capacity discharge and they started working. Disconnected the battery cables and hooked up a wire across the positive and negative. Hooked uo the cables again and they started working.
    Quote Originally Posted by cancer man View Post
    Wow, I hope it's as simple as that!
    I'm no mechanic but disconnecting battery cables, then inserting key and cycling it through ACC/run/start a few times has reset a few electrical issues in my life.
    Feb 2009
    Saab 9-5
    Oh and make sure the hood is fully closed some models the wipers won't operate if the hood is partially or open all the way.
    Mar 2006
    Thanks guys, i will try all of this as i haven't done it yet.
    Definitely get the circuit diagram and eliminate anything as a failure point - which sounds like you've done 90% .
    I know MB uses the hood sensor as a go/nogo circuit to prevent the wipers from operating with the hood open for eg. so might be the same setup.
    Also, on several times I've bypassed a wire that is suspect, direct from the fusebox (after the fuse) to the affected unit thats supposed to be getting 12v. Its pretty hard to find a bad wire buried under the hood.
    If the bypass works, then you've found the bad connection.
    Mar 2006
    Small update. Got the TIPM installed, did a hard reset by connecting the battery cables together overnight. I got the wipers to work, but only on low speed. No intermittent, no high speed and when you got to the off position they stop in the middle of the window unless you time it perfectly.
    Swapped the stalk back to the original one just to eliminate that possibility and it did not change anything.
    Could the second motor failed, sure but not likely.
    Any other tips? At least the wife has some form of wipers now but it's still not perfect.
  1. Electrical help/advice needed
    By Speed_69 in forum Home and Garden
    Latest Threads: 10-05-2016, 05:15 PM
  2. Electrical advice needed.
    By spikerS in forum Home and Garden
    Latest Threads: 02-13-2016, 06:31 PM
  3. Fs: 2009 Dodge Journey Awd R/t *SOLD*
    By +AsiaN+ in forum Cars, Trucks, Motorbikes, and Trailers
    Latest Threads: 03-16-2015, 07:26 AM
  4. fs : 2009 Dodge journey SXT
    By X_EVO_X in forum Cars, Trucks, Motorbikes, and Trailers
    Latest Threads: 01-10-2013, 03:41 PM
  5. FS: 2009 Dodge Journey SXT
    By J-Rhombus in forum Cars, Trucks, Motorbikes, and Trailers
    Latest Threads: 11-20-2009, 01:14 PM
