Lawnmower blade sharpening - Beyond.ca - Car Forums
Results 1 to 12 of 12
Thread: Lawnmower blade sharpening
    Jul 2007
    Blue boy
    Default Lawnmower blade sharpening
    How is everyone sharpening their blades and how often?
    Aug 2011
    If its bad.. I throw it to the bench grinder. If it isn't too bad I'll just use a flap disc.
    There are attachments for things like a dremel but never used them.
    May 2009
    2015 GMC 2500HD Dirtymax
    Angle Grinder than a belt sander to finish them off.
    Calgmonton/AB
    Foothills Sharpening Company does it for something like $16 and it comes out like a RazorLazer.
    Aug 2003
    I bought this and have sharpened my blade just once in two years. Will probably do it a bit more often now that I have this sharpener
    https://www.amazon.ca/Smiths-50603-M...gateway&sr=8-1
    Oct 2004
    Calgary/Alberta
    VW tiguan
    I used to angle grinder it but it only takes a few minutes with a hand file and you take off less material and get it just as sharp.
    S.E. (not the drrty south)
    Blandness
    This on my die grinder. Not sure if the balancing is that detrimental, but it makes me feel good.
    https://www2.lowes.ca/product/mainte...ing-kit-325841
    Jul 2008
    '16 F150 Lariat, SW20 MR2
    Nice to see im not crazy just using an angle grinder.
    Jul 2006
    R.F. is an entity that is everywhere
    I use a bench grinder and hand file for the finishing touch. I was worried about balance this last time because my father in law ran the mower over some rocks with it and I had to smooth out some good gouges so I did a static balance using a big upside down bolt that I ground the end to a rounded end the blade could pivot and balance on. I worked one side a little more until it was balanced. It really purrs smooth even though it was probably overkill.
    1983 Dodge W150 Power Ram. 360/NP435/D44/9.25
    Apr 2004
    2013 Q5
    I need to do this as I ran over something I shouldn’t have. Any tips on holding it in place if you don’t have a bench vise?
    Stampede Central
    is easy to spot
    I don't even have any of the tools above but I guess my first task would be to figure out how to get it off the mower before finding someone / somehow to sharpen.
    Calgmonton/AB
    It's easy. I did it, and I'm more about pens than swords...
    Disconnect spark plug (if you're a pussy).
    Tip mower on side (NOT on gas tank side).
    With gloves, hold blade while ratcheting bolt loose. Use brain to squeeze blade and ratchet together to loosen if it's stuck.
    Remove blade and take to sharpening store.
    Installation is reverse of removal.
    There are a variety of YouTube videos that somehow take 8+ min to explain what I just did, but search those if you desire.
  1. Replies: 2
    Latest Threads: 07-07-2019, 06:10 PM
  2. Lawnmower blade sharpening?
    By GREENBOY in forum Home and Garden
    Latest Threads: 07-19-2010, 03:19 PM
  3. Skates sharpening
    By TomcoPDR in forum Health and Fitness
    Latest Threads: 12-30-2007, 01:43 PM
  4. Image sharpening
    By Aleks in forum Photoshop Gallery
    Latest Threads: 09-24-2007, 08:45 PM
  5. Sharpening skates
    By D'z Nutz in forum Sports, Health & Fitness
    Latest Threads: 03-11-2007, 07:19 PM
