School me on vacuums - Page 4 - Beyond.ca - Car Forums
Page 4 of 5 FirstFirst ... 3 4 5 LastLast
Results 61 to 80 of 98
Thread: School me on vacuums
  1. #61
    N/A
    Quietly burning through dust bags like its 1980 all over again.
    So if they have bagless now, what will be your next poke at them be for?
    Will fuck off, again.
  2. #62
    Sep 2005
    I diagnosed my Dyson, one of the prongs in the plug broke internally. Cut it off and replaced it, easy and cheap fix.
    Quote Originally Posted by The_Rural_Juror View Post
    Miele makes a bagless unit now. That will be my next purchase when my next Dyson dies.
    On sale now at Costco.ca $250off until Nov 21: https://www.costco.ca/miele-blizzard...100380833.html
  3. #63
    May 2008
    Wildflower Ranch
    Neo-Liberal Anarchist Mobile
    Quote Originally Posted by phreezee View Post
    Thanks vacu-broski.
  4. #64
    Wasnt that actually what makes a better vacuum system? I thought that was posted on here.
    Paper bags perform better than bag-less.
  5. #65
    Sep 2003
    Defender, Allroad
    They definitely perform better, but I guess it's the cost of them, turning people off. Singling out the non ballers
  6. #66
    Yea Im no baller but I got one for the condo a while back - https://www.amazon.ca/Miele-41CAE005...6Y9EEQB&sr=1-4
    But I thought the whole 'power adjustment' was a gimmick, I mean who WOULDNT want maximum suction power?? Then I tried vacuuming the floor (lino) and the damn wouldnt budge!! (stuck).
    Turns out VTEC on a vacuum is too much sometimes.
    I understand now.
  7. #67
    May 2008
    Wildflower Ranch
    I probably would rather buy paper bags than replacement filters. Miele filters for the bagless need to be changed every 50hrs.
  8. #68
    Cochrane, AB
    Trucks
    Most other bagless simply have washable filters. No maintenance costs.
  9. #69
    May 2008
    Wildflower Ranch
    I have owned five Dysons with four of them being handhelds. The handhelds are great but I wouldn't mind more suction and range. However I hate reaching into the crevasses of the bagless to clean the bin thoroughly.
  10. #70
    The Dyson V11 stick seems to solve both those problems now - over 40 min of (realistic) cleaning time with the power head on one charge. Up to 80 minutes with low suction and non-powered attachments. "Turbo" mode is 10-12 minutes only, but it's not designed for continuous work. Automatic power/suction changes when you cross floor surface types and a real-time countdown of your remaining battery life. Objective testing also shows it to be the first cordless stick vacuum to hang with the big upright plug-in types for suction. With that in mind, I am thinking of getting one against my better judgement - but I am not sure I'll be able to get over how unreliable they are for the cost of entry ($900). A cordless stick vacuum that can actually clean well and last long enough on one charge to do the entire house is very tempting, but Dyson reliability and build quality is garbage. The biggest downside aside from the fact that it will probably break right after the warranty is up is that you can't even change the battery - and charge time is 4.5 hours. If you can get over those things, it's the best cordless stick vacuum out there based on my research anyway. LG makes a close competitor (CordZero A9) but it's very difficult to find in Canada.
  11. #71
    May 2008
    Wildflower Ranch
    The issue with the testing is that they are comparing the turbo mode with a corded vacuum. Realistically, people will vacuum at normal speed. I recall seeing estimates of 35 "air-watts" at normal speed. A corded vacuum would be up around 180-200 "air-watts".
    Still the best cordless out there when you use the power brush (the 40 min assumes no power brush iirc).
  12. #72
    May 2004
    You can replace the battery if it fails on a Dyson cordless. It's just a couple of screws and about $80-90 for the battery.
  13. #73
    That's a good point, you do have to run it in boost to get the crazy suction which cuts the battery life down significantly. I think the idea is that low/medium is enough to completely clean most things, but you have boost if you need it. You are also supposed to use boost with the mini motorized head for upholstery, car mats, etc. I guess regardless of air watts, it seems to do just as well or better in the pickup tests as the corded vacuums, so perhaps there is a point where brush performance outweighs raw suction power. They take sand and grind it into a carpet with a rolling pin and it picks up pretty well the same as the corded vacuums on Auto mode, which is either low or medium power depending on the surface.
    Our usage would be primarily the fluffy head on hardwood/tile, which is what got me interested in it in the first place. It seems to pick up the really fine dust well and won't tangle hair which is an issue currently. I just hate cords, so when a vacuum came out that can easily do an entire house on one charge I was intrigued, but I am nervous of Dyson's reliability and how every vacuum repairman seems to say they are garbage.
    40 minutes is actually with full power brush (either the fluffy head or the torque head) medium power (or "auto") in the case of the V11. These are screen shots from some YouTube videos I found very informative comparing it with the previous model:
    And here's the industry standard test where they weigh a set amount of sand (100g), grind it into a carpet with a rolling pin, and see how much it picks up - the results suggest the vacuum is optimized to pick up pretty much everything on medium power, and compared to the V10, medium power has seen the biggest improvement:
    Quote Originally Posted by lamp_shade_2000 View Post
    Good to know, thanks. I guess non-user replaceable just assumes people don't own a screw driver haha.
  14. #74
    Sep 2012
    For $900 that thing had better suck my dick.
  15. #75
    Yeah the price of entry is pretty ridiculous, especially since it will probably break the day after warranty is up. Not sure if it's worth it, I am torn. I would love no cords though.
  16. #76
    Sep 2012
    I have an older Dyson cordless, it's okay, but yeah the whole thing is basically plastic. The head gets stuck now though. Not sure how fixable that is.
  17. #77
    Brand new heads are only around $100 if memory serves me, so not too bad. Apparently they have a repair center in Calgary, at least that's what The Bay told me.
  18. #78
    Sep 2012
    Hmm, maybe I should take a look. Yeah they have a few repair shops in town.
  19. #79
    Feb 2009
    AB
    I‘be had my Miele C3 since Dec 31, 2017 and we vacuum our kitchen and living room everyday cause of the rug rats. We’re on our third bag. Those suckers hold a lot of dirt. It’s great never having to empty a bin and deal with the dust cloud storm. Love the retractable cord, hit the button and it’s all ready to be stored away within 5 seconds.
    If my Miele broke, I would go out and buy another one instantly without waiting for a sale. Used to be a Dyson ball and cordless guy until it broke on us 3 times, and same with our friend’s and parent’s units.
  20. #80
    N/A
    Quote Originally Posted by dingmah View Post
    Quit that, you're gonna enrage the Dyson peeps. Fellow C3 owner for quite a few years, the thing just keeps going and going.
  1. Kirby Vacuums
    By GOnSHO in forum Home and Garden
    Latest Threads: 01-26-2011, 09:37 AM
  2. Central Vacuums
    By 89coupe in forum Home and Garden
    Latest Threads: 11-03-2010, 06:58 PM
  3. Handheld vacuums
    By D'z Nutz in forum Home and Garden
    Latest Threads: 10-30-2009, 09:38 AM
  4. where to buy ORECK vacuums in cgy?
    By nonlinear in forum Computers, Consoles, and other Electronics
    Latest Threads: 08-29-2008, 05:10 PM
  5. Dyson vacuums, is it worth it?
    By stellerGT in forum General
    Latest Threads: 11-15-2007, 12:02 AM
