Lawn Thread - MEGA - Page 3 - Beyond.ca - Car Forums
Page 3 of 132 FirstFirst ... 2 3 4 13 ... LastLast
Results 41 to 60 of 2623
Thread: Lawn Thread - MEGA
  1. #41
    Mar 2006
    Looking outside now i am pretty happy i was out fertilizing at 930 last night.
  2. #42
    V167
    Recommendation re any specific fertilizer I should be putting down now?
    The Green Max stuff is nitrogen rich, continuing with that would be ok?
  3. #43
    Jun 2003
    Canada
    GMC Sierra
    I've read that fast acting nitrogen is what you want to use, Green Max should be good.
  4. #44
    Jun 2003
    Canada
    GMC Sierra
    @nismodrifter you mentioned you have a crabgrass problem, perhaps consider using a pre-emergent this fall and again early spring. Something like this: https://www.rona.ca/en/green-cross-w...954-1-12675399
    I think Scott's makes one as well
  5. #45
    Quote Originally Posted by sxtasy View Post
    I don't think those do anything to crabgrass. Do they?
  6. #46
    Jun 2003
    Canada
    GMC Sierra
    I don't have personal experience with the product, but it says right on the bag it provides crabgrass control. I'm planning on using it next spring. Can't use it right now cause I have new seed on the front and back.
  7. #47
    Medicine Hat/Calgary
    toyotas, mitsu, and a ford
    Gonna post my little project that started with removing a small apple tree that was going to fall over, that then spiraled way out of control to an all summer project.
    I never really gave much crap about my yard for the first 5 years and generally thought of lawns as a waste of water. The lawn got zero maintence or water for the entire time and baiscally turned into a dirt field full of weeds. I wish i had a picture of it before I started.
    Heres the first picture i was able to grab off my secutiry cameras. This is probably a month in of trying to "fix" the lawn. I removed the apple tree that was located where I built the firepit. I just added a second row of bricks to the edging around the tree, dug all the roots out, put some weed barrier down and filled it with pea gravel. Removing that apple tree made me realize how much work it is to remove a tree so you can see I called in a proffesional to remove a giant 40' pine tree along the fence.(along with 3 giant pines in the front yard)
    In this capture the stump has been ground down and I removed the flower bed and edging that was by the shed and planted grass. Was my first time planting grass seed and it turned out well. Grass really greened up since I gave it a good rake to get all the thatch out and started watering every other day.
    Here I just did some spot overseeding and had to dig all the roots and edging out of the pine tree area. Lots of hard work went on here.
    Then I decided to pull up some of the brick patio because some of it heeved from a tree root growing under it.
    Here it is today on the second day of grass growth.
    Didn't use any chemicals, fertilizers, or even aerate the lawn. Weeds were pulled with a dollar store weed puller.
  8. #48
    May 2014
    Pt Cruiser
    2 sections harvested and lawn mowed. Bring on fall!
  9. #49
    Jun 2003
    Canada
    GMC Sierra
    nice progress, looking good crazyjoker. Nice property Bavarian.
    - - - Updated - - -
    My backyard is starting to come in thicker, two weeks now since seed. Spread an application of starter fertilizer today.
    click for larger version
  10. #50
    May 2014
    Pt Cruiser
    Thanks that lawn will be the end of me. Over 60+ hours taking care of the grass and sage brush on it this summer. If any of you folks are into smudging, I got ya covered.. are you in the OK sxtacy?
  11. #51
    Jun 2003
    Canada
    GMC Sierra
    Morning! Yard work day, looking forward to it. The front yard came back pretty nice after the low cut and power rake/seed, there is still some evidence of my herbicide spraying, yellow/white spots but they are growing out.
    I get to mow the newly seeded backyard for the first time. I picked up a used manual reel mower for cheap, it's light and easy to maneuver on the new grass. It was recommended to me to keep a low cut on it for a while (1.5").
  12. #52
    Jun 2003
    Canada
    GMC Sierra
    Well, early winter is hitting most of western Canada, so lawn season is coming to a close very soon unfortunately. I did some research on the pre-emergent weed (and crabgrass) controls I recommended that are available here in Canada and the general consensus is they suck and are way too expensive. This product is much cheaper and more effective, one bottle should last most homeowners many years https://www.seedworldusa.com/product...-control-5-lbs
    Label and list of weeds it controls: https://www.domyown.com/msds/PRODIAMINE_65WDG_Label.pdf
    It is a product that's shipped from the US, so duty may apply. I'm going to order one and try to get it down mid October if the weather cooperates.
  13. #53
    Apr 2004
    does this prevent quackgrass too?
  14. #54
    Jul 2007
    the upside-down
    Edge Sport, F-150 EcoBoost
    There is no crabgrass in Alberta....it's quackgrass, and unfortunately there is no silver bullet fir it because its a grass, and you can't spray for it without killing the turf. The best way to keep it at bay is healthy turf. You can get some round up and a water dropper and put a drop on each blade, but it's time consuming. You can also let it grow out a bit (it grows about 30% faster than regular grass), wrap a dowel in a rag, and then soak the rag in round-up...then swoop the dowel across the taller quackgrass without hitting the turf.
    - - - Updated - - -
    Quote Originally Posted by cet View Post
    I'll me interested in seeing everyone's projects. I'll be doing grass next year and still haven't decided which way to go.
    Sod is still the best. Seeding from scratch is tricky and very fickle, unless you're on a acreage and have time to wait. Overseeding on a struggling lawn is a good way to go.
    freshprince
    -Jan 2006-
  15. #55
    Jun 2003
    Canada
    GMC Sierra
    Quote Originally Posted by freshprince1 View Post
    - - - Updated - - -
    I haven't had to deal with quackgrass yet, but sounds like your advice is spot on. Other strategies are mow it out or pull by hand:
  16. #56
    Jan 2007
    We installed sod in our backyard this summer, Any advice on if and when to use fertilizer? Ie. Scotts turf builder for fall?
  17. #57
    Only 15min from Aspen!
    Nothing interesting anymore
    Last week, before it snowed. Do it this weekend though.
  18. #58
    Jan 2007
    Any recommendations for a handheld spreader?
  19. #59
    V167
    I purchased the scotts one, with manual rotary mechanism. I saw they have a battery powered one too but felt its probably less reliable than manual one. Very happy with the purchase. Was about to get a rolling spreader but figured it takes up too much space for something I'll need just few times in a year.
  20. #60
    Jun 2003
    Canada
    GMC Sierra
    I didn't have much luck with the Scott's hand held spreader, it broke on me after a few uses, I've gotten good use out of their walk behind spreader though.
    Might be one of the last mows of the season for me. I'll post some before and afters of what I started with in the spring. I really like the little Fiskars manual reel mower I've been using in the back yard, clean and low cut.
    Started with this in the spring:
    Backyard reel mowed at a little more than an inch:
    This was a few months ago:
    Think I might go look at this unit in the classifieds and experiment with some really low cutting next year, this unit supposedly will cut as low as 0.5"
  1. LF: Mega Man ZX & Mega Man ZX Advent for DS
    By Despair* in forum Video Games / Consoles
    Latest Threads: 06-04-2010, 03:32 PM
  2. Calgary Flames MEGA THREAD: 2006-2007 Edition
    By Kirbs17 in forum Sports, Health & Fitness
    Latest Threads: 06-23-2007, 01:38 PM
  3. Calgary Flames MEGA THREAD: Info, Chat, Discussion
    By l8braker in forum Sports, Health & Fitness
    Latest Threads: 08-29-2006, 02:44 PM
  4. Fs: **mega Misc. Thread!!!**
    By cycosis in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 08-21-2006, 09:47 PM
  5. The 2006 World Cup Soccer Mega Thread
    By RickDaTuner in forum Sports, Health & Fitness
    Latest Threads: 07-13-2006, 07:04 PM
