Towing: Torque vs Horsepower - Beyond.ca - Car Forums
Results 1 to 20 of 30
Thread: Towing: Torque vs Horsepower
    S.E. (not the drrty south)
    Blandness
    Default Towing: Torque vs Horsepower
    A question for anyone smarter in vehicle physics than I am.
    I know generally speaking, Torque gets you going "off the line", and HP gets you going faster, when you're already in motion, but what about going uphill, at highway speed while towing? Does torque come into play then?
    Calgmonton/AB
    I've never heard the best explanation, but for me, torque is the ability to move something (twist wheels), at all. Power is the ability to apply that torque at a higher rate of speed.
    Torque is force x distance (ie moment arm) so it's Newton Meters which is equivalent to Joules (energy) because work is force x distance moved.
    Power is Joules/second in Watts.
    So, you can think of power as in rate of torque.
    I bet others can do better.
    :sad:
    Mar 2009
    Silverado
    Its all about power under the curve in the powerband.
    https://x-engineer.org/automotive-en...wer-vs-torque/
    Great read.
    Quote Originally Posted by Gestalt View Post
    Im the one with a learning disability....
    Technically the NE
    ‘Berta Special
    Torque gets you moving, power lets you move at speed.
    That and lack of torque can be essentially solved with gearing, but nothing can fix a lack of power.
    Flying the friendly skies
    100% SAVAGE
    Well, Horsepower is a function of Torque and RPM, so, an engine with higher Torque MUST have higher HP at that same RPM. So, to me, just go to the source, and get the torques.
    Double-meat sub dreams.
    Public Mobile referral code: 88M4Y9
    Smiles for free: https://forums.beyond.ca/threads/411...something-nice
    Technically the NE
    ‘Berta Special
    Except that typically in practice, extra HP typically comes from higher operating RPM’s rather than higher torque.
    That being said. Just get more of both and you will want for nothing.
    100% SAVAGE
    I feel like you disagreed with me, by agreeing with me.
    Mar 2009
    Silverado
    Peak horsepower should give a better representation for the scenario in the OP. At highway speed (+ incline + load) the engine will likely be operating beyond the max torque and will be operating near peak power.
    A wide flat torque curve leading up to peak power is ideal
    Blandness
    Just curious, because of the new Ford and Chevy 1/2 ton diesels. Gobs of torque, but under 300 hp. Makes me wonder how it would compare to a gasser with 300+hp, but less torque. Specifically in my scenario with hills and trailers.
    Mar 2009
    Silverado
    According to motor trends powerstroke f150 review they can be gutless while towing on the highway.
    https://www.motortrend.com/cars/ford...t-test-review/
    C5Z, Duramax
    Area under the curve and peak HP matter most imo.
    Oct 2006
    Parked in Baygirl's garage.
    2019 F150 Lariat 3.5L BOOST!
    The easiest way for me to explain it is like so:
    Horsepower = how fast you can go
    Torque = how fast you will get to your top speed
    You can have HP, but no TQ, but not the inverse. You can essentially create all the TQ you want with creative enough gearing with very little HP.
    Boosted life tip #329
    Girlfriends cost money
    Turbos cost money
    Both make whining noises
    Make the smart choice.
    Originally posted by Mibz
    May 2009
    Medicine Hat
    Trucks and junk
    More torque means you can hold gears longer. I don't know what's better or worse, but I think it's nicer being able to pull hills in 6th rather than dropping to 5th or 4th.
    2007 GMC 2500 Duramax
    1992 GMC C2500 454
    1991 GMC C1500 350
    1981 GMC C1500 454
    Technically the NE
    ‘Berta Special
    Except I am more on the “bring on the rpms” camp haha
    100% SAVAGE
    Yeah, I've towed with a bunch of engines, and having to rev to 4500 is fine for short distances, but annoying as hell for longer periods.
    The Ford 5.4L trucks I owned were like that. Needed ALL the rpm for headwinds and hill.
    Blandness
    Quote Originally Posted by dirtsniffer View Post
    That kind of answers my question. Now I want to see a towing "shoot-out" up the Coquillhala
    C5Z, Duramax
    I haven’t driven a 3L F150 but I drove a Ecodiesel towing 3000lbs and it was fine until around 100km/h. Above that it’s pretty damn weak, not much in the way of passing power. I am excited to drive a 3L Duramax half ton but sad it won’t come in Trail Boss trim level.
    Technically the NE
    ‘Berta Special
    I don’t think any of the half ton diesels are really towing beasts from what I have read.
    Serious half ton towing ecoboost is where you want to be.
    - - - Updated - - -
    Quote Originally Posted by Twin_Cam_Turbo View Post
    I think it will come in AT4 if TB is a need. Also from what I understand there are 2 trail boss trims so maybe one has and the other doesn’t? I know for 19 you couldn’t get TB with a 6.2 for example but that should be changing for 20.
    Oct 2006
    Yup. If you need to be towing any serious type of load, the 3.5 EB in the F150 is the best on that market. I have towed 10K+ loads, and the truck just soaks it up. Horrible gas mileage when you are, but power is never an issue.
    Turbos cost money
    2017 Civic Hatch ST
    Torque is king for towing - just look at the HP/TQ ratios of diesel pickups, semi trucks, etc. Something like a Ram 3500 diesel has ~400HP but ~1000TQ. If you're towing a huge load up a hill in the mountains, you want lots of low RPM grunt, you don't want the engine screaming at 6000 RPM.
  1. More torque and horsepower for b18b
    By armystrong20 in forum The Garage
    Latest Threads: 12-27-2009, 02:53 PM
  2. 707 horsepower and 525 lb-ft of torque Ferrari F430
    Latest Threads: 03-06-2008, 03:34 PM
  3. Torque/Horsepower Relationship n 1/4 Mile.
    By bart in forum General Car/Bike Talk
    Latest Threads: 10-10-2003, 12:03 PM
  4. Horsepower vs Torque
    By GTS Jeff in forum General Car/Bike Talk
    Latest Threads: 02-11-2003, 02:13 PM
  5. 1001 Horsepower production car...!!
    By Yellow_Fly_Red in forum General Car/Bike Talk
    Latest Threads: 01-10-2003, 10:09 AM
