Speaking of asking for a friend. How many of these do I need to be net zero? Anyone got a map of them around the city? Again, strictly hypothetical friend scenario
Texas is in for a hot week. Lets see if they can make it through.
Cocoa $7,000 per tonne.
So I saw a residential home with ~90-100 panels quick count
That’s like a 36-40kW system. How are they getting away with this??
Not a farm, but to be fair it was out of the city limits. Not an acreage either.
-H.P. Lovecraft
Is there a maximum? Isn't more better?
You can absolutely mount perfectly vertical. That is the entire reason they make bifacial modules.
I read somewhere you can’t produce more than your high usage case. Or something to that effect, the installations aren’t meant to be power plants.This quote is hidden because you are ignoring this member. Show Quote
I’ll look up more info
-H.P. Lovecraft
Every big residential installation should have power wall or similar to time shift into the evening.
I’ve yet to actually figure out where the regulation limiting you to install roughly the same capacity as you consume comes from. Enmax has rules set out for micro generators up to 250kW. Part of me thinks it’s just a rule for the solar club pricing as part of a subsidy. Still feels like it’d just be better to go for a monster of a system in the long run
The hassle is fixed, bigger seems better if you have space.
One of the solar wholesalers seem to have taken down their retail sales webpage. Probably bracing for impact on Enmax prices next month.
Are solar panels an unfair advantage?
It's the 120% rule and has to do with your panel/service.
https://www.greentechrenewables.com/...izing-120-rule
Yep and keep all the power to yourself.This quote is hidden because you are ignoring this member. Show Quote
The example of 200 amp panel is an issue right there. If you want to go "all in" and have enough sun coverage in well spaced out Alberta, 400 amp would be the minimum.
Then its just a matter of making sure you oversize the cabling to handle the load and minimize losses. For anything DC, something closer to stranded welders cables or something better than standard Romex if doing AC.
I wonder... Get a couple cheap acres of prarie that has access to electricity but not water or sewer. Put up a shed, load it up with a sleeping bag, declare it a residence - and then just plaster the whole thing with solar panels?
Looking at the ENMAX site here is what it states:This quote is hidden because you are ignoring this member. Show Quote
After installing solar, a bill will change primarily on four lines:
Energy Charge: This is the cost of the energy consumed from the grid. With solar, energy generated by solar modules is consumed first, so this line item should be lower than for a home without solar installed.
Micro-generation Credit: This line is added to a bill after solar is installed. It represents any energy generated by a home solar power system that is not consumed during the month. Excess solar energy from a home solar power system is “sold” to the grid at the same rate being paid for incoming electricity. The amount of money a home solar power system is credited depends on a variety of factors, including the number of solar modules installed, a home’s energy needs and the homeowner’s current electricity rate.
Distribution Charge: This charge has a fixed component which will not change with solar as it is charged per day, and a variable component, which is charged based on consumption from the grid. Because there is a reasonable expectation that grid consumption is lower with solar, this charge should also be lower compared to a home without a solar power system if a system performs as expected.
Transmission Charge: Much like the distribution charge, this charge may have a fixed and variable component. In most areas of Alberta, it is only variable based on consumption from the grid so will most likely be lower compared to a home without a solar power system if the system performs as expected.
The Balancing Pool Allocation is also positively impacted by lower usage but has an overall negligible impact on the bill as the amount is typically quite low.
The Rate Riders, Local Access Fee and Administration Charge are not impacted by micro-generation.
Awesome. I think the ROI is looking better than ever. Throw in an EV and it’s onThis quote is hidden because you are ignoring this member. Show Quote
-H.P. Lovecraft
Solar panels that face the sun at noon are dumb?
Should solar panels be mounted vertically along east west? It does actually make real world sense considering the duck curve and energy storage, where you want a little more energy in the morning to charge batteries earlier and ride through the morning peak, as well as maximizing energy output as the sun sets on evening peak.
One year update, my 6.3kW system produced 8.5MWh in the 12 months it's been live. Just multiply that by your rate and figure out if it's worth it, not including transmission + fees.
Winter production wasn't very good at all.
So like, was it worth it for you?This quote is hidden because you are ignoring this member. Show Quote
That's almost 2 grand in savings with the higher summer rates isn't it? Plus the extra bit you gain from selling carbon credits. So at ~15k installed cost that's only 7 years payback. Seems pretty good deal.
