any refrigeration experts here? - Beyond.ca - Car Forums
Results 1 to 6 of 6
Thread: any refrigeration experts here?
    Oct 2003
    ute
    Default any refrigeration experts here?
    My Frigidaire Commercial (yeah right), stand up deep freeze started to only cool to -4C or so and stay there.
    I pulled the evaporator shroud off the top/back and i see the coil is only showing snow/ice over a certain section, with the rest not frozen. This looks like a classic loss of coolant or a leak in the sealed bits?
    The condenser coil seems to be getting enough cooling, and the compressor kicks on. (Not sure if the compressor is operating at 100% or not).
    Before I ditch it, I want to make sure that it might not be something else that is fixable.
    How's the airflow across it?
    Cochrane, AB
    Trucks
    My best internet diagnosis is a refrigerant leak. The frost looks normal. Nearly all other failure modes would leave it completely dead. Or possibly a thermostat going bad.
    6.7 CUMMINS, E50 AMG
    Check evap fan, defrost low limit switch, coil heater
    Oct 2003
    ute
    Quote Originally Posted by legendboy View Post
    the evap fan is working fine.
    just googled the low limit switch
    It should be a disk type. It could be causing the heater to not come on. I'm not sure what else it would be interlocked with, the condensing unit maybe
  1. Replies: 1
    Latest Threads: 10-22-2014, 04:54 PM
  2. Replies: 3
    Latest Threads: 08-15-2014, 09:42 PM
  3. Anyone good at Refrigeration?
    By stealth in forum Campus Chat
    Latest Threads: 03-13-2011, 10:51 PM
  4. LF: Commercial Refrigeration
    By Isaiah in forum General
    Latest Threads: 08-12-2009, 10:26 AM
  5. Digital camrea experts, digital storage experts LOOK
    By MYKN in forum Computers, Consoles, and other Electronics
    Latest Threads: 07-21-2004, 04:05 AM
