New Owner FAQ. My experience anyway:
Cold Weather FAQ:
Q. Does the car make weird noises and is it normal?
A. Yes. Car will runs pumps, motors and all sorts of things before and after a drive. If it hums, the car is usually doing something.
Q. Car "bangs" when supercharging?
A. When it's cold outside, thermal expansion causes the battery to make "banging" noises. Totally normal.
Q. What is the blue part on my battery status / what is the snowflake?
A. Your battery is cold and the energy in part of the battery is unavailable until it warms. The battery will warm with driving.
Q. How much does cold affect my range?
A. Depending on temperature, it can drop your range by 50% or more. This means that an SR+ range would drop to 200 ish kms when it is -20C to -30C.
2021 Model 3 and all Model Y cars have a heat pump. This generally improves efficiency 15% when the temperature is mild (0C to 10C).
Q. Why do my wipers suck?
A. Tesla stock wipers have some shitty coating on the blades. Clean them with Alcohol. They work better.
Q. Wiper fluid only comes out at the bottom?
A. Yeah, someone in their infinite wisdom won't let you control when and where you want wiper fluid to come out. Applying while driving will have the remnants go all over your driver's side window. apply sparingly at speed.
Q. My car never gets XXX km as shown on my battery meter.
A. That's the theoretical maximum. Heater, headwind, fat asses, etc.. will all affect your range to the negative. Use the Energy graph if you really want an estimate of your range. People online all say, put it on "Percentage" and run it like your smartphone.
Charging FAQ:
Q. Do I need a 240v connection?
A. Depends on your use case. A 120v 15A outlet will charge your car at 7km/h. With a Wall Connector (Sold by Tesla for $600) you can charge at 71km/h getting a full tank in about 5-7 hours. You can get a 14-50 Nema adaptor ($22) for the included connector that will charge at about 48km/h. I have survived on 120v, but when you decide to go out of town, you have take a visit to the supercharger to top up which might not be convenient.
Q. Max charge?
A. The guidance is to charge to 90% daily and plug in when the car is not in use. Anything above 90% should be reserved for trips. It is said a high SOC (State of Charge) damages the battery. It is also said a low state of charge damages the batter (below 10%). Therefore you real usable battery range is 80% of the stated range by Tesla for daily use.
Member Referral codes:
mo_money2supe:
https://ts.la/simon82305
benyl:
https://ts.la/moon14483
To be expanded.
