Steering wheel control hookup - Beyond.ca - Car Forums
Results 1 to 3 of 3
Thread: Steering wheel control hookup
    Jun 2004
    90 DB1, 03 RL1, 07 YK1
    Default Steering wheel control hookup
    I have a 07 Honda Ridgeline and just got a made in China touchscreen head unit. The unit has steering wheel control but there is only one wire (labelled key1) on the harness that came with it. Everything that Iíve read online typically refers to key1, key2 and a swc ground wires coming out of the unit which is not the case with mine. On the Ridgelineís factory harness, there are supposed to be two wires, the control wire positive and the control wire ground. Iím sure the control wire positive is connected to the key1 wire but where do I connect the control ground wire to? Does the head unitís ground wire make sense?
    Calgary is so much like an iphone: iCalgary - There's a bylaw for that.
    Mar 2006
    '73 Buick, '03 Ruckus, '17 Ridgeline
    Quote Originally Posted by frozenrice View Post
    I have a 07 Honda Ridgeline and just got a made in China touchscreen head unit. The unit has steering wheel control but there is only one wire (labelled key1) on the harness that came with it. Everything that I’ve read online typically refers to key1, key2 and a swc ground wires coming out of the unit which is not the case with mine. On the Ridgeline’s factory harness, there are supposed to be two wires, the control wire positive and the control wire ground. I’m sure the control wire positive is connected to the key1 wire but where do I connect the control ground wire to? Does the head unit’s ground wire make sense?
    I have found in the last 2 stereo i installed the OEM units were grounded through their mounting frame and not via a wire. Typically you can just add a ground in the dash. For steering controls i am not sure how you could possibly add a ground
    Jun 2004
    I ended up wiring the factory ground for the steering wheel control wire to the ground wire on the head unit and it worked (sort of). Now I'm having trouble programming the damn buttons. LOL.
  1. FS: EK4 SIR STEERING WHEEL, MOMO STEERING WHEEL, Civic Headlights, GSR Seats
    By simonseys in forum Automotive Parts [Aero/Styling/Interior]
    Latest Threads: 06-23-2013, 12:53 AM
  2. Aftermarket Steering wheel and cruise control
    By LUDELVR in forum Cosmetic and Styling Modifications
    Latest Threads: 03-03-2010, 11:30 AM
  3. FS: Prelude Steering Wheel w/ Cruise Control + Airbag 5th Gen
    By whitebb6 in forum Automotive Parts [Aero/Styling/Interior]
    Latest Threads: 05-02-2007, 08:32 AM
  4. steering wheel volume control and aftermarket
    By RawB8figure in forum In Car Entertainment / Electronics
    Latest Threads: 10-01-2005, 03:17 PM
  5. Steering wheel w/AIRBAG, cruise control..how easy to remove?
    By ND4SPD_HS in forum Calgary MR2 Owners Club
    Latest Threads: 04-11-2005, 09:24 PM
