Hey guys,
Might have some needs to pull things around in the near future, and for that I need a hitch for my truck.
What should I be looking for here? I am hoping for a general one size fits all that can be used generically for any towing ( not talking about anything heavy enough to need a true WD hitch, but I am open to buying a WD hitch and not using the equalizer bars or whoever that works. I hear WD aren’t generally compatible with boat surge brakes so that might rule them out?)
In the short term it’s likely utility type trailers, might look into some kind of watercraft in the spring so if it can also serve that role that would be awesome.
Truck is a little higher than typical stock, but nothing excessive for Alberta (2” lift, 32’s). Not sure if that affects things much for ball height etc. Or if I should be considering something with adjustable height.
I’m pretty in the dark here so interested in hearing opinions, or regrets on features etc. that people have had. Seems like a simple problem but I don’t really know where to start.
I am sure @ExtraSlow is salivating already
