Building a Zwift setup - Beyond.ca - Car Forums
Page 1 of 5 1 2 ... LastLast
Results 1 to 20 of 100
Thread: Building a Zwift setup
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Default Building a Zwift setup
    So as winter is setting in I have been thinking more and more about setting up a stationary system that I will actually want to use.
    So I guess what Iím really stuck on is whatís the most realistic riding options right now? You have trainers that vibrate if there is cobblestone, there is the whole kickr eco system with the climb and headwind. Then you have a couple smart rollers that give you way more movement... or what I just found today while checking on the inside ride rollers again was the e-flex for the kickr trainers, but doesnít look like it would work with the climb as you need inside rideís floating fork stand. Would be cool if they designed one for the climb, but I donít see anything pointing to that happening?
    I think I am leaning towards a kickr w/headwind for now, then when the inside ride e-flex is back in stock, grab one of those... but also not sure if Iíd just be better off with their smart roller which has safety features from flying off the thing unlike most rollers. But worried about the noise and added tire wear.
    Anything else I should be looking at? Would be good if I can take advantage of some Black Friday sales which might help sway me in a more definitive direction!
    As for the actual zwift portion, Iím thinking just the extra 42Ē tv I have kicking around and hook up the laptop, anything Iím missing there?
    The SHBARUS
    I recommend either the kickr or the neo plus a fan. The kickr is kinda fixed and the neo can flex somewhat. All the rocker stuff and the climb are kinda gimmicky. They really don't add much to training. Of course if money is no problem, there is the kickr bike. If you have too much money, there is the tacx magnum. The kickr bike will be hard to get at the moment, the magnum is even harder. Rollers are good for form but not so much for strength. You can't really do low rpm high resistance on rollers. I have used my rollers on zwift. It's so weird to spin at +90 rpm and barely moving on an incline lol.
    Apr 2006
    Cowtown
    10' 4Runner SR5
    The Neo is sweet.
    Also a $400 fan? Are you high?
    Follow me on Instagram and Facebook!
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    The Neo is sweet.
    $250usd... and wahoo is going to have a Black Friday sale, so will wait and see what that looks like... but it’s soooooo sweet! I think it will add a lot to the sensation of speed with zwift.
    The “rocker” setup I’d be looking at looks like it would add a lot...
    This has me leaning towards the kickr, plus if I want to try out a vr headset then it won’t be as sketchy as doing so on inside ride’s rollers
    The goal is enjoyment over sheer exercise, so if the gimmick adds enjoyment then I am more likely to actually use the thing.
    Have you guys used the smart rollers with the resistance? The inside ride claims to be able to mimic up to a 10% grade
    Jan 2003
    The kickr headwind fan was 275 CAD at ridleys. But the product listing seems to have been removed.
    For PC / Mac setup, I think you will need a USB / Ant+ dongle.
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Laptop does have Bluetooth, would that work?
    Apr 2006
    Cowtown
    10' 4Runner SR5
    Most of these need the ANT+ dongle to work well.
    That headwind trainer seems interesting but kinda gimmicky. I have a Neo now that I need to setup...my pants are getting slightly tighter than I remember haha
    The sweet thing about the fan though is that it can increase the flow based on heart rate, this is especially nice when getting on the bike early in the morning. I find it beneficial because typically when i start out i'm a little chilled to have the fan on full blast but as I warm up with my heart rate it increases. Prior to the headwind i'd have to stop mid warm up to go turn the fan on, now it just works.
    Apr 2006
    Cowtown
    10' 4Runner SR5
    At $150, I'd be fine with it. Regular $400 is insanity!
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    I’d have it set to speed... cooling is for winners
    May 2005
    Wankels!
    Quote Originally Posted by bigboom View Post
    Fortunately they make fans with remotes for those on a budget
    I warm up with fan off, then turn it to low until I get too warm, then set it to full blast.
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    So “pre-black Friday” sale has the 2018 kickr refurb on for $700usd, don’t think there is any changes? Still works with headwind and climb... do I buy or do I wait for the actual Black Friday sale... Hrm
    Also thinking I will just get the trainer now then use up the wellness spending account and in the new year use up the fresh balance of it on some toys for it
    Jul 2006
    Quote Originally Posted by Penguin_Racecar View Post
    My setup is similar. I have a fan on max plugged into a smart outlet.
    Once I am warmed up I have to ask Alexa to turn on fan. It is ghetto but very cheap. I think 2 fans are $25 and the smart plug was $10.
    I would spend good money on a trainer as it makes a bigger difference than one would think. I got a Stac Zero for $650 and truthfully it kind of sucks.
    Jan 2003
    Quote Originally Posted by sneek View Post
    In what ways? With 4iiii taking over and releasing an updated version of that trainer, I was tempted to give it a try.
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Well, turns out I should have just ordered it earlier. Same deal today but their site was down almost all day. Finally got confirmation though! Kickr will be on it a way and should be under $1100cad all said and done.
    Jul 2006
    Quote Originally Posted by ZeroGravity View Post
    It rides really poorly to be honest. I have the old version with the wheel weights so it isn't a direct comparison.
    It just doesn't spin up and down very nicely. It is also quite difficult to find a good wheelset/axle system that works with it. Ended up spending another $200 just to get the trainer working. My friend ended up with a Direto and it rides far nicer for about the same money when you consider the extra wheelset. It is a lot of work to get started.
    My first trainer came out the box broken so I actually went and met them in Cochrane. Very nice and knowledgeable bunch, but truthfully I couldn't recommend it unless it was 3-400.
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Finally showed up! Need to bring a fan down, didn’t help that the house was heating up to “home” temp either
    The SHBARUS
    You gonna need a floor mat unless you hate your carpet.
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Quote Originally Posted by lilmira View Post
    Yeah I have some industrial carpet squares in the garage I’m going to bring in
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Much better! Need to adjust the fan though... doesn’t get the face. Maybe I’ll grab a second fan from the garage
    Also hooked up a HR monitor for the first time... that’s a fun stat to watch haha
    So realistic... drop my chain on the 1x11 just like real life
    But yeah, rode pretty close to the same distance as my regular commute, but like an extra 100m of gain... feels right and metrics are more or less inline for my effort
  1. Zwift online cycling
    By lilmira in forum Cycling
    Latest Threads: 02-28-2019, 05:24 PM
  2. Replies: 14
    Latest Threads: 05-09-2013, 07:01 PM
  3. Considering building 4-door ITR
    By three.eighteen. in forum Performance Modifications
    Latest Threads: 02-23-2003, 10:18 PM
  4. 240sx Nissan Building Meet in california *PICS*
    By Zephyr in forum Cars, Bikes, Machines
    Latest Threads: 10-24-2002, 10:44 PM
  5. Building a 13 Second Drag Car, help me.
    By jbell in forum General Car/Bike Talk
    Latest Threads: 10-08-2002, 07:41 AM
