Gaming/VR Build Advice - Page 2 - Beyond.ca - Car Forums
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 21 to 40 of 46
Thread: Gaming/VR Build Advice
  1. #21
    Oct 2013
    Blackfalds aka north RD, AB
    Bikes.Car.Truck
    Bumping. Currently looking into a new rig. I have a MSI laptop that doesn't cut it for min specs on some games that are out or coming out. Looking for a desktop.
    I want this new system to last for a number of years. Looking for something that will run everything on ultra settings, mainly upcoming flight sim, Cyberpunk, etc. VR is also a must. What I have picked so far is:
    CPU: Intel Core i9-10940X 3.3GHz
    Motherboard: X299 Chipset
    RAM: 64gigs DDR4
    Hard Drive: 2TB SSD
    GPU: RTX 2080Ti 11GB
    Power: 700 watt supply
    Is the 2080Ti the way to go? Or is AMD the hot ticket now?
    96 Ram 1500-Sold
    03 RSX-S-Sold
    03 350Z-Sold
    07 CBR 600RR-Sold
    11 Honda Fury-Sold
    14 CBR 1000RR-Sold
    14 Ram 1500-Current
    14 Optima LX-Sold
    15 Victory Highball-Current
    15 Genesis 3.8 Ultimate-Current
    18 Husky 701SM-Current
  2. #22
    Quote Originally Posted by 16hypen3sp View Post
    RAM: 64gigs DDR4
    Hard Drive: 2TB SSD
    Based on GPU benchmarks alone, the 2080ti is the hottest thing for now.
    https://www.videocardbenchmark.net/high_end_gpus.html
    However, I dont keep up with bleeding edge tech as its generally not feasible for so many reasons - there could be another card that works way better for your specific applications that has been just recently released.
    One thing to note, insist on GOLD or PLATINUM series PSUs. Dont cheap out on that.
  3. #23
    Duplex city
    Phanbus
    Not my world either, but the top tier at https://www.logicalincrements.com/ is probably pretty decent.
    Make the world a radder place, grow a mullet.
    Public Mobile is the best, just like Phil Collins' mullet.
  4. #24
    Mar 2010
    Fiesta ST
    I haven't really looked at the 10940x but I think the Ryzen 3950x is better value and still more powerful though I guess it depends what game is optomized for which.
    Nolan
  5. #25
    Avants, Estates, Variants, Wagons, Touring
    If your goal is VR/Gaming performance above all else - Z390 board w/ 9700k oc'd.
    This is my build - on the performance side of performance per-dollar ratio.
    CPU - INTEL CORE i7 - 9700k - eBay - NEW - $450CDN
    GPU - EVGA GeForce 1080ti - eBay - USED - $600CDN
    RAM - G.SKILL DDR-3200 2x16GB - NewEgg.ca - NEW - $210
    CASE - Dan Case A4 v4.1 w/ Asetek 645LT (Noctua chromax HS upgrade) - OcUK - NEW - $407.53CDN
    SSD - Samsung 970 Evo Plus 1TB - Amazon.ca PRIME - USED - $250
    FAN - Noctua A9x14 PWM - Memory Express - NEW - $24
    PSU - Corsair SF750 Platinum - Amazon.ca - NEW - $200
    MB - AsRock Z390 Phantom Gaming itx/ac - Amazon.ca - USED (Prime warehouse likenew) - $230
    Corsair K68 - $80
    Total apprx - $2350 - all prices incl tax.
    Could've saved quite a bit with a different case, but DAN is made by Lian Li and the quality is tops. 7.2L makes it console sized. The riser cables are ~$100 alone.
    For a GPU, GTX 1080Ti is best value per dollar. It's neck and neck with an RTX 2080 on most titles, and costs ~$300 less. This setup drives 3440x1440 @ 100FPS on max gfx with most titles, save for RDR2. I wanted to fuck with race sims during quarantine so I did my best 'budget' build:
    Valve Index is on the way to complete the package.
    Originally posted by InRich
    tell her I'll pick her up in the vette
    The X5 i bought earlier this year really is FULLY LOADED though not a single option missing including infrared night driving
  6. #26
    ^ curious why you, with a hot rig - go with a small case?
    The Thermaltake Core cases are wall mountable and offer 10x better air movement. Most GPUs at idle dont even spin up their fans (I did a conversion recently where they were spinning at idle).
  7. #27
    Sep 2016
    Calgary, Ab
    Zonda CRV
    U guys still going with Intel..? Are there pro's over that compared to AMD in that price range?
    I was watching a bunch of 'build a pc' vids on youtube. Most Im playing with the idea of building a gaming rig. AMD is pushed a lot.
    Have any of you noticed any price increases on the computer parts and items not being in stock?
  8. #28
    Quote Originally Posted by zipdoa View Post
    Certain usage cases are advantageous for AMD processors, namely applications that can take advantage of all the threads/cores. AMD gaming performance is inferior to Intel, dollar for dollar.
    GPU is 65'C under full load w/ OC 80mhz/330mhz
    CPU is 75'C under full load, stock clocks
    Case is silent when not under load
    Not a fan of big nerd towers. Prefer minimalist lowkey design and portability. I can throw this in a pelican case well under carry-on dimension limits. Makes it easy to demo VR at a friends house. There's very little compromise going SFF if you build it right.
  9. #29
    calgary ab
    EVOX
    RAM: 64gigs DDR4
    Hard Drive: 2TB SSD
    The 2080ti can run 1440p with rtx on over 200fps with a mild OC easily but you will need a sick monitor to take advantage.
    Just a heads up the 2080 ti is an oven and you will need to either liquid cool or get a really nice case with upgraded fans if you want to OC. It was making my temps bounce off max with stock settings in both a meshify c and a cooler master case with this fan setup. Ended up going with the phantek p600s and it solved my issues.
    If you buy the 2080ti and dont OC it is a waste of money IMO.
    I personally would go with a 850w power supply minimum because the price difference is minimal. Also for the price 64gig is not really worth it IMO but if you got the paper it will be future proofed for a while. The setup you have above will be better then any next generation console for a long time so I wouldnt be worried at all
    Help grow my channel!
    www.youtube.com/SteveChambersXP
  10. #30
    Oct 2013
    Bikes.Car.Truck
    ^ The 2080Ti is really that hot? I was going to go with liquid cooling for the CPU only but I guess I should do both.
    96 Ram 1500-Sold
    03 RSX-S-Sold
    03 350Z-Sold
    07 CBR 600RR-Sold
    11 Honda Fury-Sold
    14 CBR 1000RR-Sold
    14 Ram 1500-Current
    14 Optima LX-Sold
  11. #31
    Quote Originally Posted by scboss View Post
    Those are some very nice fans - quiet too.
    - - - Updated - - -
    Before going with GPU liquid cooling, perhaps try the open cases I mentioned earlier - the have mATX sizes as well (what I am using for a workstation). The difference in heat management is striking.
  12. #32
    calgary ab
    EVOX
    - - - Updated - - -
    Couldn't agree more with open case. I legit chose the one i did because it has cloth mesh vs foam but I was considering open case after the temps i got with the other cases it was super frustrating.
    Yeah unfortunately lol. You can get them with pre installed liquid rads but they are $$$$$$. TBH I know its huge but im actually getting better temps on my cpu now with this setup then I was liquid cooled with a 240mm rad. Noctua is ugly af but they are amazing.
  13. #33
    Oct 2013
    Bikes.Car.Truck
    What do you guys think of the Ryzen 9 3950X paired with the 2080 Ti 11GB and 2TB M.2 PCIe NVMe SSD + 2TB 7200RPM SATA 6Gb/s???
    96 Ram 1500-Sold
    03 RSX-S-Sold
    03 350Z-Sold
    07 CBR 600RR-Sold
    11 Honda Fury-Sold
    14 CBR 1000RR-Sold
    14 Ram 1500-Current
    14 Optima LX-Sold
  14. #34
    Mar 2010
    Fiesta ST
    Would make for a great computer for a long time. Though the cost difference of your extra HDD going from 2tb to 4 or 8tb is pretty small so might be worth it to just go bigger if you have a ton of media files downloaded but if not 2tb on both drives is a ton of space already. Just make sure to try and get some good ram as well that's pretty high frequency.
    Nolan
  15. #35
    Oct 2013
    Bikes.Car.Truck
    Sounds good. I was looking at 64GB Dual Channel HyperX™ FURY DDR4 XMP at 3200MHz.
    96 Ram 1500-Sold
    03 RSX-S-Sold
    03 350Z-Sold
    07 CBR 600RR-Sold
    11 Honda Fury-Sold
    14 CBR 1000RR-Sold
    14 Ram 1500-Current
    14 Optima LX-Sold
  16. #36
    What's your usage case? You have a workstation processor with a gaming card - typically a 3950x would be paired with a Quadro given typical usage scenarios.
  17. #37
    Oct 2013
    Bikes.Car.Truck
    Quote Originally Posted by born2workoncars View Post
    I have read that the 3950X is both a workstation and gaming processor.
    96 Ram 1500-Sold
    03 RSX-S-Sold
    03 350Z-Sold
    07 CBR 600RR-Sold
    11 Honda Fury-Sold
    14 CBR 1000RR-Sold
    14 Ram 1500-Current
    14 Optima LX-Sold
  18. #38
    Jun 2011
    Camaro SS
    Some game engines like Frostbite are CPU intensive, the more cores and threads available the better, more so if you're looking at the rig being a long term use build as games and engines become even more hardware intensive.
  19. #39
    May 2010
    Calgary,AB
    2015 Kia Forte5 SX
    I just picked up a new gaming laptop
    MSI Gaming Laptop:
    GeForce RTX 2060 6 GB GDDR6
    Intel Core i7 9th Gen 9750H (2.60 GHz)
    16 GB Memory
    512 GB NVMe SSD
    Looking at that 2080Ti the card is over 2k canadian.
    I would love to just upgrade or get a new gaming desktop but I dont really have anywhere to put it at this time with the whole lockdown thing - our office has been converted into my wifes working space.
  20. #40
    Mar 2010
    Fiesta ST
    MSI Gaming Laptop:
    16 GB Memory
    512 GB NVMe SSD
    Yup but it'll still be a beast for many years to come. Even a 1080 still dominates most games and is a 4 year old card now.
    Nolan
  1. FS: Gaming Desktop with 27 Inch gaming monitor and logitech gaming keyboard and mouse
    By Stormv64 in forum Computer Hardware & Peripherals
    Latest Threads: 04-24-2018, 11:19 AM
  2. Replies: 87
  3. Help me build a gaming PC!
    By yellowsnow in forum Computers, Consoles, and other Electronics
    Latest Threads: 09-19-2008, 01:35 AM
  4. Help me build a $1500.00 gaming pc
    By ugotahondaeh? in forum Computers, Consoles, and other Electronics
    Latest Threads: 04-26-2007, 05:15 PM
  5. Help me Build A New Gaming PC Rig
    By s--dime in forum Computers, Consoles, and other Electronics
    Latest Threads: 02-02-2007, 10:26 AM
