smart devices - Wifi problems - Beyond.ca - Car Forums
Page 1 of 3 1 2 ... LastLast
Results 1 to 20 of 51
Thread: smart devices - Wifi problems
    Default smart devices - Wifi problems
    I think this has been discussed tangentially in other threads, but the advice is spread out, and I'm still confused. I've having connectivity issues with a few smart devices on the 2.4GHz band of my house wifi. This is happening in areas near to the router, so I'm certain it's not a signal strength issue.
    Currently running a single Asus RT-AC86U.
    So what's best practice for stable connectivity to smart 2.4 GHz devices?
    - regularly reboot the router (monthly)? if this solves the issue, and it needs to be rebooted more often, replace the unit
    - do not use ISP devices as anything but a stupid modem (use this device as a router)
    - update firmware, but again as above - if this fixes the issue temporarily, its time to replace
    - ensure router does not get too hot
    - if you have older devices, sometimes both TKIP and AES (encryption methods) needs to be enabled. Less secure WIfi, but usually not an issue for the average home user.
    calgary ab
    4x4
    Take it off your primary router is job #1. Put it on it's own with it's own for security - use an analyzer to check for what channels actually quiet near you.. generally weak antenna weak tx power - they need a quiet network to use.
    watch router firmware/firewall setup.
    like the IPcameras - the big one is getting them off the primary network, the traffic just seems to get too much for a lot of them especially when you've got some streaming/gaming/etc boxes dominating the traffic.
    So separate 2.4ghz network for the smart devices?
    ^ if you have just a few things, no. But if you have say 6, 1080p wifi cameras, yes - they should have their own dedicated/physical AP at that point.
    calgary ab
    4x4
    That's typically the recommendation, especially if you have streaming and gaming devices on the same network.
    Also lets you manage their security a bit more judiciously since a lot of them have some seriously stupid programming.
    My "smart" devices are currently 6 Google speakers, 4 hue bulbs and three plugs. No cameras or anything taking much bandwidth.
    Jan 2006
    Axis powers
    Some smart devices have issues with special characters in the password, I have a separate hidden network for mine that doesn’t have anything other than letters and numbers
    Sig nuked by mod.
    Thaco's Avatar
    Oct 2004
    Rage2
    Some smart devices also have issues with 5ghz networks if the ssid is the same, typically if you shut off 5ghz in the router to set up the devices and then re-enabl it again later its fine, but sometimes its better to rename the 5ghz network and only use it for devices that support 5ghz
    User title molested by Rage2.
    ^^ Fact Checked
    Router is Asus RT-AC86U, Telus Modem is fully bridged. Running current firmware, and is located in open area, so no issues with airflow, and I assume it's not overheating.
    we do reboot the router regularly, and I just set it up to reboot once a week automatically. That's a handy feature in the Asus software.
    Then youre looking at a wifi device with issues - try rebooting IT.
    Oct 2003
    Mazda 3
    What kind of connectivity issues?
    Are they dropping out all the time? Only when you're using it? They show on the log that they are dropping out all the time?
    Sep 2005
    2011 lexus is250 awd
    I would look at your logs, upload your logs and I can take a look for you.
    Without those we are just speculating. For all you know this might be an endpoint issue and your router could be just fine
    Quote Originally Posted by logs
    SSID: "SSIDNAME"
    RSSI: 0 dBm SNR: 0 dB noise: -93 dBm Channel: 6
    BSSID: 2C:FD:A1:A2:AC:10 Capability: ESS ShortSlot
    Supported Rates: [ 1(b) 2(b) 5.5(b) 6 9 11(b) 12 18 24 36 48 54 ]
    VHT Capable:
    Chanspec: 2.4GHz channel 6 20MHz (0x1006)
    Primary channel: 6
    HT Capabilities:
    Supported MCS : [ 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 32 ]
    VHT Capabilities:
    Supported VHT (tx) Rates:
    NSS: 1 MCS: 0-11
    NSS: 2 MCS: 0-11
    NSS: 3 MCS: 0-11
    Supported VHT (rx) Rates:
    NSS: 1 MCS: 0-11
    NSS: 2 MCS: 0-11
    NSS: 3 MCS: 0-11
    Interference Level: Acceptable
    Mode : AP Only
    Stations List
    idx MAC Associated Authorized RSSI PHY PSM SGI STBC MUBF NSS Tx rate Rx rate Connect Time
    BC:EE:7B:1A:89:8A Yes Yes -67dBm n Yes Yes Yes No 2 72.2M 1M 06:31:05
    F0:EF:86:A1:41:8F Yes Yes -67dBm n No Yes No No 1 72.2M 72.2M 06:31:06
    30:FD:38:B2:11:F5 Yes Yes -66dBm n No Yes No No 1 72.2M 72.2M 06:31:10
    14:2D:27:A7:EC:73 Yes Yes -77dBm n No Yes No No 1 72.2M 1M 06:31:14
    68:57:2D:43:A7:0D Yes Yes -55dBm n Yes Yes No No 1 72.2M 6M 06:31:15
    68:57:2D:43:7C:17 Yes Yes -66dBm n Yes Yes No No 1 65M 6M 06:31:15
    SSID: "SSIDNAME"
    RSSI: 0 dBm SNR: 0 dB noise: -86 dBm Channel: 161/80
    BSSID: 2C:FD:A1:A2:AC:14 Capability: ESS
    Supported Rates: [ 6(b) 9 12(b) 18 24(b) 36 48 54 ]
    VHT Capable:
    Chanspec: 5GHz channel 155 80MHz (0xe39b)
    Primary channel: 161
    HT Capabilities:
    Supported MCS : [ 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 ]
    VHT Capabilities:
    NSS: 1 MCS: 0-11
    NSS: 2 MCS: 0-11
    NSS: 3 MCS: 0-11
    NSS: 4 MCS: 0-11
    NSS: 1 MCS: 0-11
    NSS: 2 MCS: 0-11
    NSS: 3 MCS: 0-11
    NSS: 4 MCS: 0-11
    Mode : AP Only
    Stations List
    8C:F1:12C:05:F2 Yes Yes -68dBm n Yes Yes Yes No 1 135M 6M 01:57:49
    58:A0:23:663:57 Yes Yes -64dBm ac No Yes Yes Yes 2 650M 390M 05:44:38
    7C9:5C:5C:1E:E1 Yes Yes -67dBm ac No Yes No No 1 390M 263.2M 06:32:21
    44:07:0B:F1:A5:A5 Yes Yes -62dBm ac No Yes No No 1 433.3M 433.3M 06:32:26
    7C9:5C:10:E9:53 Yes Yes -68dBm ac No Yes No No 1 390M 390M 06:32:26
    44:07:0B:35:18:13 Yes Yes -63dBm ac No Yes No No 1 390M 433.3M 06:32:26
    30:FD:38:03:70:E2 Yes Yes -62dBm ac No Yes No No 1 433.3M 433.3M 06:32:33
    Are these the logs you mean?
    Sep 2005
    I'd like to see the general log please
    but from the general wireless logs there is a client issue. You don't appear to have any intermittent drops
    "Mode : AP Only"
    Are you sure the ISP modem isnt doing any routing? On the ASUS routers' home page you should see as below........OPERATION MODE = WIRELESS ROUTER
    I cna't post that, as the forum software is itnerpreting it as having smilies in it, and those count as images, and there's too many. Not sure the best way around that.
    - - - Updated - - -
    "Mode : AP Only"
    Hermmmm, that's weird. lemme see what's up.
    You want whats in the yellow circle:
    Thaco's Avatar
    Oct 2004
    Rage2
    - - - Updated - - -
    click the
    Code:
    code :)
    button in advanced mode, or wrap the log in [code] tags
    ^^ Fact Checked
    Put it between [ code][ /code] tags (without the spaces).
    Code:
    :) no images bitches
  1. Sonos and other Wifi Streaming Devices
    By schocker in forum Computers, Consoles, and other Electronics
    Latest Threads: 04-18-2024, 04:04 PM
  2. FS: iPad Mini Retina 32GB White WiFi w/ Smart Cover
    By knr in forum Consumer Electronics
    Latest Threads: 10-14-2014, 12:40 PM
  3. FS: 32GB iPad Mini WiFi + Grey Smart Cover
    By jnkyrd in forum Consumer Electronics
    Latest Threads: 06-01-2014, 11:25 AM
  4. FS: iPad 2 16GB WiFi + 3G, Smart Cover
    By mittensthekitty in forum Consumer Electronics
    Latest Threads: 03-17-2012, 10:09 AM
  5. SMART cars all that smart?
    By statusdodge in forum General Car/Bike Talk
    Latest Threads: 08-27-2008, 05:52 PM
