https://www.gizmochina.com/2019/12/1...fast-charging/
On the horizon. Kinda expected 100 watt charging, but I guess they need room to sell next years model.
Cocoa $11,000 per tonne.
I am genuinely curious, is there any non-tin foil hat stuff that occupies your mind? Even this could be considered another conspiracy post by you?This quote is hidden because you are ignoring this member. Show Quote
Will fuck off, again.
Be cool when additional battery chemistries become mainstream. Could have positive implications in a whole host of consumer products.
Well, according to NASA: If it takes 1,000 technologies to put a man on mars, the USA has 800 of them and China has 80 - Then it is not worth it to collaborate because the USA has more to "lose" and the final goal can't be achieved anyhow.This quote is hidden because you are ignoring this member. Show Quote
In my mind, nothing I say is a conspiracy or rumor - just greater than 50% chance of being truth.
The new rumor is that the Quantum computer was pushed by China for the sole reason of cracking 2048-bit encryption that the US used for decades. Again, USA has so many more secrets to lose, it only makes sense that the USA would be the last to push the tech that ultimately destroys their own IP. It would also be retarded to share factual data with other nations so that they have successful moon landings, depending on how "dickwadish" you consider the USA to be.
BTW: The $20 lightning cable that requires active circuitry to determine if the cable has degraded below 10 watts capacity, is simply the worst charging design in history. If you ask me. Even a $2 Micro USB can do 15 watts.
I can say this now because it looks like Apple is finally ditching lightning cables (for power) forever. A true case of USA 10x more expensive, and literally worse.
China and Japan have always had more advanced "metallurgy" than the USA, no doubt the reason that solar panels cannot be produced in the USA without being 10x more expensive. If you ask British people, the North American household three prong electrical outlet is pure retard.
https://www.theverge.com/2019/11/20/...-apple-factory
I wouldn't say lie, so much as be overly optimistic about expectations.
Wake me up when Solid State Battery becomes norm.This quote is hidden because you are ignoring this member. Show Quote
Are graphene batteries stable? Lipos have gotten a bad rap lately for lighting on fire. Especially the whole samsung phone thing.
Cheap or poorly designed LiPos are a hazard, or of people abuse them or ignore basic usage guidelines, otherwise they are extremely reliable overall.This quote is hidden because you are ignoring this member. Show Quote
Sort of. I'd say Samsung is pretty reliable and they fucked up pretty bad. Everyone is obsessed with fast charge times and try to push things to the max. They are still prone to physical damage as well.This quote is hidden because you are ignoring this member. Show Quote
You can pick your smartphone model, and google "battery fire" or "explodes" or whatever and you will see no brand is immune to it. The biggest reason the Note 7 had such a bad time was because unfortunately it happened on a plane so it got all the press coverage due to the obvious hazard that created.This quote is hidden because you are ignoring this member. Show Quote
I've personally owned hundreds of LiPo products in my life and literally never experienced a single issue or failure (even on the ultra-cheap hobby LiPos), but I take care of them meticulously. Also think of how many smartphones are out there, and battery fires and the like are few and far between, at least in terms of what is reported. Overall they are very reliable.
Its coming!
TDK has the first solid state battery on the market right now.
https://www.tdk-electronics.tdk.com/en/ceracharge
Its only useful for real time clock backups due to size and cost BUT manufacturing should catchup and get the costs down for larger sizes in the next few year i bet.
Automotive grade should arrive in 2024/25. But expect to see these in cell phones between now and then.
