Help | Upgrading RAM (doubling from 16gb to 32gb) - Beyond.ca - Car Forums
Results 1 to 10 of 10
Thread: Help | Upgrading RAM (doubling from 16gb to 32gb)
    Sep 2006
    calgary / alberta
    VW R32 Turbo
    Default Help | Upgrading RAM (doubling from 16gb to 32gb)
    Getting black screen when adding 2 sticks of 8gb Samsung 8GB DDR4 2400MHZ 1Rx8 (M378A1K43CB2-CTD )
    Is this a Voltage issue?
    Here's a snapshot to my build https://valid.x86.fr/9uga2p
    Originally posted by sputnik
    Cell providers are the next Blockbuster video stores.
    Jan 2003
    I'm not very well versed in computer setup / hardware.
    Have you tried removing the old ram and just run the new ones?
    Also noticed that your current setup is saying you're running single channel using slot 1 and 2. Not knowing the details of your motherboard, if you put your old ram sticks on 1 and 3, will it go to dual channel?
    Lastly, if the new ones work by themselves, try putting the new ones on slot #1 and #3, and the old ones on slot #2 and #4. Or vice versa. The timings / rated speed of your new ram is different from the old ones.
    Sep 2005
    2011 lexus is250 awd
    Take off your overclock and retest
    Incompatible RAM.
    Intel® Core™ i7-6700 Processor
    Memory Types (supported)
    DDR4-1866/(2133 <- what you have now)
    DDR3L-1333/1600
    https://ark.intel.com/content/www/us...-4-00-ghz.html
    Aug 2011
    Strathmore
    2005 Dirtymax
    Quote Originally Posted by cam_wmh View Post
    You start messing with ram and going to 32gb may take a bit of finesse
    May 2003
    calgary, ab
    Always should only be combining ram of the same brand, i.e. samsung with samsung, not samsung with kingston although different brands may work. Ram is very sensitive, need to also keep the voltage the same, single channel with single channel not dual etc.
    Sep 2006
    calgary / alberta
    VW R32 Turbo
    Thanks fellas!
    Sep 2006
    calgary / alberta
    VW R32 Turbo
    Thanks again fellas.
    Quote Originally Posted by ZeroGravity View Post
    Exactly this. I was lazy and didn't try swapping the slots. I've had mixed speeds of RAM on previous builds (1866 w/ 1600).
    I didn't think I was OC'd, but updated my BIOS regardless.
    Incompatible RAM.
    DDR3L-1333/1600
    I'm confused here. Here's the updated build snapshot. https://valid.x86.fr/ydfxs0 Bandwidth is faster than the compatibility link you shared. 2133 vs 2662 uh wtf?
    EDIT: Found some discussion on Toms Hardware, saying the faster bandwidth would work.
    https://forums.tomshardware.com/thre...stock.2707426/
    Quote Originally Posted by gatorade View Post
    Yeah, it's why I feared finicky, brand incompatibility.
    Feb 2008
    Not Aspen
    teslo murdel free
    Incompatible RAM.
    DDR3L-1333/1600
    Incorrect, you can put faster mhz, not slower
    Quote Originally Posted by eglove View Post
    I have gone through this exact same scenario as OP with a build - black POST - I bought RAM that was compatible with the board, but NOT the CPU (RAM was too fast).
    The moment I got CPU compatible RAM the system booted just fine. You can adjust timings and speed after that.
    You are contradicting what INTEL is specifying on their site with regards to compatibility.
    Good luck.
  1. Replies: 1
    Latest Threads: 08-25-2011, 11:20 PM
  2. Doubling of pictures
    By msommers in forum Photographer's Corner
    Latest Threads: 03-17-2010, 08:23 AM
  3. Upgrading RAM?
    By ZMan2k2 in forum Computers, Consoles, and other Electronics
    Latest Threads: 02-11-2008, 06:27 PM
  4. Fs:hd & Ram Ram Ram Ram Ram Ram Ram Ram
    By Crazyx88 in forum Computer Hardware & Peripherals
    Latest Threads: 09-28-2005, 09:08 PM
  5. Upgrading hard drive and RAM on laptop....where to go?
    By Mckenzie in forum Computers, Consoles, and other Electronics
    Latest Threads: 03-21-2005, 11:53 PM
