25C in my garage with my Calcana infrared. Still in shorts socks and slides.
Is it gas or electric?This quote is hidden because you are ignoring this member. Show Quote
From what I read, the only disadvantage of those seems to be your tools and anything you have in storage containers stays cold and doesn't warm up. Did you find that to be the case or is everything pretty warm?
Man I want to see what happens when the complex hybrid drivetrain has a hiccup and you are stranded in -35 wearing shorts and sandalsThis quote is hidden because you are ignoring this member. Show Quote
@benyl will pick him up.This quote is hidden because you are ignoring this member. Show Quote
Slide on Gucci slides... Slide around.
https://ca.news.yahoo.com/calgary-zo...235800782.html
Calgary Zoo cancels Penguin walk. This is a prime story to tell the kids when the world has burned to a crisp.
Cocoa $11,000 per ton.
They do this every winter. Not unique.This quote is hidden because you are ignoring this member. Show Quote
Also not unique, the ExtraSlow system in effect:
LOL battery not start?
No, it starts because I put it on a charger in the cold weather.This quote is hidden because you are ignoring this member. Show Quote
It’s like an electric car. ABC = always be charging.This quote is hidden because you are ignoring this member. Show Quote
Oh didn't see it being a chargerThis quote is hidden because you are ignoring this member. Show Quote
Pretty sure my truck used all 800cca today to start... even the blower for heat was screaming.
155,000BTU, do the plastic bits on your car get soft and malleable very quickly too?This quote is hidden because you are ignoring this member. Show Quote
That's a really personal question.
We've all seen Tik-Tok share before.This quote is hidden because you are ignoring this member. Show Quote
Those of you with natural gas fireplaces, check the exhaust vents. My basement fireplace, which we rarely use, and just sits on pilot light, froze it's exhaust shut today. Was dumping some natural gas into the basement for a short while.
Unclogged the frost/ice with a screwdriver, but since we rarely use it, also turned off the pilot light and gas valve until this cold snap is over.
4Runner has never had issues starting, even after sitting for days. Typically plugged in. Not sure what the rebranded Toyota batteries are but the one I have is fantastic.
Ultracrepidarian
It was dumping NG into the house WHILE the pilot was lit?This quote is hidden because you are ignoring this member. Show Quote
I suspect it wasn't much. Just a bare little bit of smell.This quote is hidden because you are ignoring this member. Show Quote
I just worry way more if it’s somehow flowing and not getting lit by the pilot. That, is scary.This quote is hidden because you are ignoring this member. Show Quote
Argh, when you say it like that it does sound scary.This quote is hidden because you are ignoring this member. Show Quote
I found the draft from this cold I'm a renter.. not much I can do. I was going to put plastic up but got delayed.
