Garage door issues - Beyond.ca - Car Forums
Results 1 to 20 of 20
Thread: Garage door issues
    May 2003
    2018 Audi RS3
    Default Garage door issues
    Another annoying cold snap question.
    Ever since Friday when we got really cold, our garage door sensors keep tripping and the door won't close.
    Have to park on the driveway, go into the garage; override the control so the door closes, and then exit through the house. 10 years in the house and this is the first cold snap we are having to do this. We also appear to be the only house I can see on my street with this problem.
    We usually have this problem in the summer with the setting sun interfering in the beam, never in the winter.
    Looking at the sensors, the one has a solid yellow / orange light; the other is a solid green light, so I don't think the sensor's are misaligned.
    Any tips / tricks we can try when it warms up and can spend the time to trouble shoot this?
    Mar 2005
    Foothills County
    is faster than yours
    Is it the sensors at the bottom of the door or could it be something binding with the cold and tripping the pressure limit when the door is closing? Not sure if your opener pad shows codes or not.
    May 2003
    2018 Audi RS3
    Quote Originally Posted by never View Post
    Yes, sensors are at the bottom
    Don't think we can. It's the standard builder push the button, with the lock pad. Nothing fancy
    Feb 2011
    2020 Tacoma DCSB
    Also double check your downward travel and downward force. With these cold temps. it's likely things may have expanded/ contracted/ shifted/ stiffer than usual etc. and it might be setting off the downward force sensor (it hits the ground but it might think there's still an inch or two of travel, it thinks it's hit something, so it goes back up). Recently had to adjust these slightly after 2 years and it's been good ever since.
    May 2003
    2018 Audi RS3
    Quote Originally Posted by Kijho View Post
    Doesn't spring up at all. Just refuses to go down.
    I'll press the button for it to go down, it will start to go and then right back up, just the damn blinky light from the overhead unit laughing at me.
    Apr 2005
    13 Cayenne Turbo
    Can't really help with your issue but would assume it's due to the cold. My door is also acting up and gets stuck going up and have to manually guide it up to open a couple times.
    Feb 2011
    2020 Tacoma DCSB
    I'd check the sensors then make sure they're clean, if there's a small speck of anything on them in the wrong spot it can throw them off completely. (And in this weather there's alot more slush/ snow/ water/ mud all around the garages usually!!) Blinking lights is definitely a sensor!
    Only 15min from Aspen!
    Nothing interesting anymore
    Probably the angle of the sensors. The metal sensor brackets contracting from being cold soaked and moving them jussst off.
    May 2003
    2018 Audi RS3
    Quote Originally Posted by skandalouz_08 View Post
    It's super annoying!
    Thanks, will check that.
    Can't wait for the warm to come. Hopefully it will fix by it's self.
    Not Aspen
    Two from Freemont
    Quote Originally Posted by nickyh View Post
    that is likely the pressure rather than the sensors. If it was the sensors, you would get blinky light without any movement.
    If it is the sensors, then the cold is causing enough vibration to misalign the beam causing it to reverse.
    There are lots of youtube videos on how to adjust the reversing pressure:
    https://www.google.com/search?rlz=1C...4dUDCAs&uact=5
    Oct 2013
    Blackfalds aka north RD, AB
    Bikes.Car.Truck
    Also check the wires going to the sensors. Sometimes my door does the same thing. Sensors were aligned. Wiring to sensor was culprit. I literally just barely moved the wires and the proper light lit up on the sensor and had no problems after that. Finicky system.
    Looking around
    Wondering what became
    Of what I once knew
    calgary ab
    4x4
    The opener blinking light is your code - count how many times it flashes, it tells you if its sensor or force that's sent it back up. Check your manual to know which is which.
    Most likely its closing force is a tad low - but likely there's a reason it's now showing rather than in years prior (ie you've got another component failing, probably a roller).
    May 2003
    2018 Audi RS3
    Quote Originally Posted by AndyL View Post
    Thanks, I'll count and check that. Super useful tip!
    May 2003
    2018 Audi RS3
    all fixed beyond, thanks for all the help!
    May 2004
    Ford, Acura
    What did it end up being and how did you fix it?
    I'm generally cute.
    May 2010
    Calgary,AB
    2015 Kia Forte5 SX
    How important is that black rubber strip on the bottom of your door. I swear mine ripped partly a few years ago and I didnt bother replacing it - my friends said his fell off last night and hes really concerned. My garage though is insulated on the walls and the roof where he thinks his is not (we live on same street). Also Im pretty sure that my garage is about 0 degrees in this weather I have a bottle of water in my car overnight that did not freeze.
    No big deal. You'll get some air leakage, and in an attached garage, it'll end up colder, but it's not going to wreck anything
    Jun 2004
    21 CX5 GT Turbo
    My garage door opener doesn't have manual force adjustment, just some automated stuff. I had the same problem in the past where it will start to go down then stop and go back up. I had to calibrate it for it to work.
    May 2003
    2018 Audi RS3
    Quote Originally Posted by schurchill39 View Post
    combo of sensor wire on the one, connection was ever so slightly loose one on. The other was just off on alignment, I expect once it warms up the alignment will shift again.
    Oct 2013
    Bikes.Car.Truck
    Regarding the bottom seal of the garage door.... it's like a sweep on the bottom of a standard door. I had mine replaced last year and life tip.... coat the seal in Vaseline to prevent it from freezing to garage floor. I did it 2 weeks ago and I've had zero issues with freezing. Life changing!!!!!
    Looking around
    Of what I once knew
  1. Garage Door - Shutting issues
    By Brent.ff in forum Home and Garden
    Latest Threads: 01-22-2019, 05:53 PM
  2. Raising my garage door- garage door advice
    By craigcd in forum Home and Garden
    Latest Threads: 04-01-2018, 09:17 AM
  3. Replies: 3
    Latest Threads: 02-25-2018, 05:54 PM
  4. Garage door rubber seal between parts of the door
    By nzwasp in forum Home and Garden
    Latest Threads: 11-05-2017, 11:03 PM
  5. Free: Overhead Door CodeDodger ACSCTO Type 1 Garage door remote
    By Zero102 in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 12-20-2009, 04:47 PM
