Testing the new clear ice cubes, very difficult to capture
I can see them clearly.
I used to think that way too back when I was young and full of dreams.This quote is hidden because you are ignoring this member. Show Quote
2007 GMC 2500 Duramax
1981 GMC C1500 454
It's probably the base spirit. I haven't tried that Pendleton myself, but sometimes with Canadian grain whiskies it sounds like letting it oxidize can really enhance the flavour.This quote is hidden because you are ignoring this member. Show Quote
Take off the cap and leave it in the sun for a few hours and then try it again. Also helps to get the fill below the neck of the bottle so there's more surface area in contact with the air.
Clear cubes, fully covered by fluid, you can't see them in your drink. Makes you look like an alcoholic with your glass totally full.This quote is hidden because you are ignoring this member. Show Quote
Also only use short glasses for the ice balls or you risk cracking a tooth. Haha
I'm no Archimedes, but something doesn't sound right about that.This quote is hidden because you are ignoring this member. Show Quote
I'll post a picture when I get into the sauce and clear ice cubes tonight.
Enjoying a quiet NYE
Found this swill lying around, what kind of ice cubes should I be using?
Make sure to pronounce it correctly, to add cred.This quote is hidden because you are ignoring this member. Show Quote
MowAy because it's French.
Fucking lots.This quote is hidden because you are ignoring this member. Show Quote
Shoot, I’m all out of snails too
I hope you have a sabre to open that.
Everything I say is satire.This quote is hidden because you are ignoring this member. Show Quote
Nope. Would an M16 suffice?This quote is hidden because you are ignoring this member. Show Quote
That's an ExtraSlow sangria?This quote is hidden because you are ignoring this member. Show Quote
It’s all going the same place.This quote is hidden because you are ignoring this member. Show Quote
I don't mix them. Well, not mixed in the glass. Mix in my belly.
