AN Hose+Fittings - Beyond.ca - Car Forums
Results 1 to 11 of 11
Thread: AN Hose+Fittings
    X5D, Fiesta ST
    Default AN Hose+Fittings
    I’m remounting the oil cooler on my car with a bigger core in a different location and I need to either create a small second AN line to extend my short line, or have a whole new AN line that’s slightly longer created. Anywhere in Calgary that does this?
    Sep 2008
    Turbo stuff
    Buy fittings and line from mopac and DIY.
    Aug 2002
    992 T-hawk Golf R
    Quote Originally Posted by Sentry View Post
    What he said.
    I have a pile of old reusable AN fittings in my garage if anyone wants to buy some.
    I like neat cars.
    Mar 2005
    Pushbroom
    Mopac / JBs both have stock and several styles of hose. What size are you doing? I’ve got a bunch of dash 10 fittings laying around.
    X5D, Fiesta ST
    I thought it was a bit of a pain to crimp AN stuff? I could just reuse the fittings on the current short line and buy a longer hose?
    Sep 2008
    NE
    Ram 1500, '68 Camaro, S14
    Quote Originally Posted by Twin_Cam_Turbo View Post
    It is, I was trying to do it the other day and got pretty frustrated haha.. you just really need to make a clean cut so nothing gets caught up when you’re putting threading the fitting on...
    Mar 2005
    Foothills County
    is faster than yours
    There isn’t any crimping involved. And yes, you can just disassemble your current hoses, buy new hose and reassemble with your existing fittings.
    - - - Updated - - -
    Quote Originally Posted by JfuckinC View Post
    If it’s getting caught because the cut isn’t clean, wrap electrical tape around the outside of the end really tightly, but with the sticky side out. That’ll compress it to allow you to get the fitting on but will also allow you to pull the tape out once you have the fitting on the line.
    Sep 2006
    There's also another option that's a little easier IMO. You can get a more economical (but still very robust) rubber hose and use push-connect ends like this: https://www.summitracing.com/parts/fra-209006-bl
    On my Locost build I used nylon braided fuel line with the usual threaded fittings, and rubber oil cooler lines with the press in fittings. Once I got the hang of heating the hose end slightly before pressing in the fitting, I thought it was a pretty slick option for non-fuel lines.
    dv/dt
    Sep 2008
    NE
    Quote Originally Posted by never View Post
    - - - Updated - - -
    Hmm I’m gunna have to try that this week haha, need to finish my fuel lines. Thanks man!
    Chevy Colorado ZR2
    Quote Originally Posted by zieg View Post
    The Push types are a lifesaver when I routed my oil and water lines to the turbo.
    Braided is unnecessary unless you want headaches.
    X5D, Fiesta ST
    Gonna pick up some hose and reuse my existing two 90° fittings since they are the right size and angle for my new core location.
  1. Coolant hose vs fuel hose
    By Hallowed_point in forum Mechanical
    Latest Threads: 04-08-2016, 10:09 AM
  2. Hose/Hose Reel
    By bspot in forum Home and Garden
    Latest Threads: 08-08-2011, 02:45 PM
  3. Using hose clamp/barb connection with AN hose
    By 2EFNFAST in forum General Car/Bike Talk
    Latest Threads: 03-03-2010, 12:01 AM
  4. FS: Standalone EMS,Aeromotive regulator,AN fittings hose
    By pgmatt in forum Automotive Parts [Mechanical Parts]
    Latest Threads: 04-18-2008, 07:44 AM
  5. Fittings
    By Taupe20 in forum General Car/Bike Talk
    Latest Threads: 10-17-2002, 05:04 PM
