Auto AC Help needed... - Beyond.ca - Car Forums
Results 1 to 18 of 18
Thread: Auto AC Help needed...
    Aug 2004
    Default Auto AC Help needed...
    2011 Ram 1500 Sport QC 5.7 L
    AC quit last summer so I used a red tek recharge kit from Canadian tire.
    Fast forward to last week when I tried it and again...No AC.
    A forum search tells me that most AC shops wont look at the system once I have used an aftermarket recharge kit on it.
    Should I try the dye kit first to try and find the leak or go straight to the seal kit ?
    Any other options to look at ?
    Thanks.
    2011 Ram 1500 QC Sport
    2017 Jeep Cherokee Limited
    @cancerman do you have a suggestion?
    Sep 2008
    Turbo stuff
    Most common AC leaks are o rings at connections, then condenser taking rocks to the tubes, then a hardline being rubbed through.
    "AC quit last summer so I used a red tek recharge kit from Canadian tire." ..... implies that you diagnosed the issue as pneumatic, rather than electrical or mechanical.
    Did the original seal kit not contain dye? If not thats where I would start then.
    Jul 2006
    NA
    Aug 2004
    I installed the "recharge kit" got cold air again and moved on...
    I didn't think about looking for a leak. After 10 years I thought it just needed a re-charge.
    Would the guages that came with the recharge kit work...or where to get a set...and where to connect them ?
    With my AC it was a mechanical issue that I was able to isolate (clutch) - but with anything pneumatic on the AC side, I've always gone to a private garage for AC servicing. They have the tools and skills to fix it or tell you to not bother.
    Aug 2004
    When it stops raining I will have to have a look at the system to see if I can spot any damage.
    Can you rent the manifold gauges ? Will they show anything if the system is empty ?
    Anyone have a set I can borrow ?
    Or recommend a shop that will look at the system even though
    I have used one of the "bad" re-charge kits...
    I mean @cancer man
    Seriously, its much easier to get a quick, 1 hr/100$ shop diagnosis - I went through all of this some years ago with buying some of the equipment and then learning how to interpret it - the pneumatic side of things involves a serious learning curve to get it right. Weights are also involved.
    I had a (certified AC) mobile tech come to my garage and did it all for me for about 130$.
    Aug 2004
    For sure...and I'm willing to do that...
    I would prefer to use a referral vs a random internet search though...
    Feb 2009
    Saab 9-5
    I'am 80% retired if you need a hand pm me..we can at least do an evac and a vacuum test for leaks.
    I've used Wrenches in the NE (diagnostic, told me nothing wrong with the pneumatic side)
    https://g.page/wrenches-automotive?share
    As well as:
    C.A.R.S. - they refilled my system after I accidentally purged it while removing a compressor clutch (took off one retaining clip too many). Tested/filled and no BS. Told me exactly what I already knew (but didnt tell them) about the AC system part that was malfunctioning (compressor clutch wire/ground lost connection).
    https://g.page/Calgary-Auto-Repair?share
    Aug 2004
    Thanks to everyone for the advice and offers to help.
    I had it in the shop yesterday and they did a pressure test and said it held for 15 minute.
    Recharged and added some dye so that if it does leak again that they can pinpoint where the leak is.
    Maybe I'll grab the appropriate UV light and check my self after a few weeks of usage...
    Hey, right on! I hope it holds and you should definitely buy a UV light.
    I've got two vehicles with a similar problem.
    Just curious what shop did you end up using? Both my vehicles AC stopped working and I'd like to take it in for a diagnosis or recharge.
    Anyone else have shop recommendations?
    Aug 2004
    Integra Tire Midnapore...next to the Bottle Depot.
    2002civic's Avatar
    2002civic is offline Held my GTI hostage and got unbanned
    May 2003
    19 SQ5/22 Pilot BE/18 RS3
    Any NW a/c shop recommendations? Parents Santa Fe A/C stopped after the winter.
  1. Auto Detailer Needed $18 pr/hr flat rate
    By DDOUGAN in forum Careers
    Latest Threads: 09-02-2009, 07:30 AM
  2. Replies: 0
    Latest Threads: 10-08-2008, 04:15 PM
  3. licenced auto tech needed performance shop
    By 88jbody in forum Careers
    Latest Threads: 05-19-2008, 11:17 AM
  4. Help TV Repair/help needed
    By 2.2vtec in forum General
    Latest Threads: 11-04-2006, 11:39 AM
  5. Replies: 29
    Latest Threads: 01-28-2004, 12:03 PM
