Lawn Sprinkler system - Beyond.ca - Car Forums
Results 1 to 20 of 22
Thread: Lawn Sprinkler system
    Jun 2020
    toronto
    Default Lawn Sprinkler system
    I got a new compressor to use it to drainage the water in the sprinkler before closing for winter. Here i am attaching a picture of the sprinkler control manifold. Can some one let me know where do i connect the compressor to pump the water out from the system.
    Thanks
    Left Coast
    Audi
    The main that goes to this tree should have a spout that you can connect the compressor into. You hook it up, turn the compressor on, and then manually turn on each zone by opening the valve on each branch. Make sure the shut off inside the house is closed as well (if you have a backflow preventor i don't know if there's anything you need to do with that).
    V167
    Jun 2020
    toronto
    Thanks mod. I do not see anything like you shown. I am sending you a picture of the outlet from the wall to the manifold. I can close the valve inside the house. Do i have to do anything in the manifold before connecting the compressor.
    ThanksName:  sprinkler wall 1.jpg
    Aug 2003
    Medicine Hat, AB
    Quote Originally Posted by tomlin View Post
    Its likely on the inside then. Snap a picture of the manifold setup inside.
    Jun 2020
    toronto
    It is the picture i send you first. In the basement there is a valve to close the supply line to sprinkler. nothing else. What do you mean by manifold setup inside.
    Thanks
    Aug 2003
    Medicine Hat, AB
    There should be a manifold inside your house where the main water comes in, distributes to the house, and heads outside to the underground sprinklers. My blow out connection is inside the house just after the shut off valve for the sprinklers.
    Not Aspen
    Two from Freemont
    Can you take a better picture of this part?
    Jun 2020
    toronto
    Thanks. I here send you enlarged pictures [ATTACH=CONFIG]92551, [ATTACH=CONFIG]92550
    Left Coast
    Audi
    Is the cap removable on that? If it is, what does it look like if you take it off (is it threaded for a hose)
    Jun 2020
    toronto
    thanks. I checked, it has thread, so i hope it is removable. I tried it is so tight i may need special tool. how do i loosen plastic thread can i spray something. i may have to find some one to remove it
    V167
    Quote Originally Posted by nismodrifter View Post
    And
    Jun 2020
    toronto
    Thanks. I am trying to find someone to open the white cap outside the house pipeline.
    Jun 2020
    toronto
    Name:  open out side.jpg
Size:  39.2 KBName:  two adopters.jpg
    Thanks. Finally I got some one to open. I am sending you the pictures
    Not Aspen
    Two from Freemont
    This is what I did and blow out my sprinklers with my compressor. got all the parts at home depot.
    You can do the same. Just close off the upstream feed and cycle through the zones.
    Mar 2010
    Dewinton, AB
    Thats the same tool I made at HD. I assume you'll need one that fits inside that cap you took off.
    Jun 2020
    toronto
    Thanks. Do I have to do anything in the manifold I shown. I do have a compressor 3 Gallon with 5 cfm. Will it do the work. I am not worried about the time taken, as I have lot of time
    Mar 2005
    POS
    ^ Doesn't look like it. 3 Gallon should be fine, I use a 5 gallon and usually two pushes is good enough for each zone until it just shoots out some light mist. Just make sure the valve inside the house is closed.
    Take this to home depot and find the parts to make yourself one of these https://www.amazon.ca/Winterize-Spri...3459467&sr=8-7 It's pretty easy, I cut an old garden hose to make mine. Or you may be able to make a direct connection for a compressor like the others posters did.
    Not Aspen
    Two from Freemont
    youtube it.
    You can manually open the zones. My experience is the manual screw strips out and you have to buy a whole new valve to fix the problem. So what I do is use the control inside the house now.
    Can't comment compressor size. CFMs is what you need, not pressure.
  1. sprinkler system winterization?
    By nzwasp in forum Home and Garden
    Latest Threads: 09-22-2015, 12:12 PM
  2. LF: Deck Expansion and Lawn Sprinkler System
    By jdmsource in forum Home and Garden
    Latest Threads: 05-22-2015, 10:06 AM
  3. Underground Sprinkler System
    By visualk in forum Home and Garden
    Latest Threads: 04-09-2010, 06:08 PM
  4. Wanted: Great deal on residential sprinkler system repair
    By pei_boy in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 06-01-2009, 03:38 PM
  5. residential sprinkler system
    By grideTLS in forum General
    Latest Threads: 03-03-2009, 07:47 AM
