Rattling Noise Driving on Uneven Surfaces - Beyond.ca - Car Forums
Results 1 to 12 of 12
Thread: Rattling Noise Driving on Uneven Surfaces
    Feb 2006
    07’ Mazda 3 Sport
    Default Rattling Noise Driving on Uneven Surfaces
    Has anyone ever heard of or experienced the rattling noise of metal on metal while driving over uneven surfaces (i.e. manholes)?
    Itís definitely coming from the rear passenger side and seems to only occur when driving over manholes, not at all on speed bumps. Any help would be much appreciated.
    Duplex city
    No longer Savage. :(
    I think that's pretty rare in your Jaguar XJ6 Vanden Plas. Although that's a great car, I guess since it's pretty old now a few rattles are not unexpected.
    Make the world a radder place, grow a mullet.
    Public Mobile is the best, just like Phil Collins haggard face.
    Quote Originally Posted by The_Rural_Juror
    no one gives maritimers shit for culturally appropriating donairs.
    Feb 2006
    07’ Mazda 3 Sport
    Lol itís a Mazda 3 Sport actually and it definitely sounds like something is loose or moving around. Definitely not a normal rattling sound.
    CTS-V, DMax, P71
    Sway bar end links. Our Mazda 3 eats them. On the fourth or fifth set.
    Feb 2006
    07’ Mazda 3 Sport
    Interesting, thatís what Iíve been thinking as well. Called Mazda and they quoted $200+ for the job. Iím thinking I could do it myself, but not sure if the length of work is worth it.
    S4
    Metal on metal noise.... only happens when driving over manholes.... mmmkaaaaayyy
    Sep 2007
    A vehicle or two
    Not sure on the 3, but every sway link I have ever worked on has been very straight forward. Worth a go I figure.
    First though, why not get under there and take a look? Any issue should be obvious in the structure or bushing.
    mazda 3 and 5s suffer from the upper rear shock mount breaking - mainly due to corrosion buildup allowed in the area (not sealed) - if you lift the affected back corner and look up at the mount, it should be obviously cracked or broken
    Also check for broken springs. They're bad for that as well. I've had to replace both on mine.
    '08.5 Mazda 3
    '90 Laser RS-T
    '07 Yamaha R6
    Also check for broken upper shock mounts.
    Duplex city
    Sounds like enough info here to get you Jaag fixed up real nice.
    2020 Subaru Forester Sport
    Last week replaced some swaybar end point links on my wife's 2009 Pontiac Vibe, pretty straight forward...until it's rusted to shit and you can't get an allen key into the center to prevent it from spinning as you try to undo the nut. $200 is pretty good if you don't want to fuck around with it. For wife's it was $82 in parts and like 3 hours of my time....didn't have a grinder and ended up cutting off with a dremel. Mine was a clunk going over jumps.
  1. FS: Ergonomic Desk Motorized Height-Adjustable Work Surfaces
    By echristopher in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 03-16-2016, 06:07 PM
  2. older 4x4 system on wet but stable surfaces
    By Redlyne_mr2 in forum Trucks, 4x4 and Offroading Zone
    Latest Threads: 11-12-2012, 09:45 PM
  3. Sr20de Rattling Noise Problem HELP!!
    By the_ace in forum Mechanical
    Latest Threads: 04-11-2005, 02:13 PM
  4. Honda Prelude 01: Rattling Noise when taking off.
    By p0d4355 in forum Mechanical
    Latest Threads: 09-17-2004, 01:07 AM
  5. Rattling noise at certain RPM
    By volvo-driver :( in forum Mechanical
    Latest Threads: 01-06-2004, 12:47 AM
