Dishwasher filling up afer a cycle? - Beyond.ca - Car Forums
Results 1 to 20 of 30
Thread: Dishwasher filling up afer a cycle?
    Default Dishwasher filling up afer a cycle?
    I'm a little stumped. Dishwasher seems to be washing fine, and draining as part of it's normal cycle. When I open the door, there's no water in there, however, after sitting a few hours, the bottom of the dishwasher seems to have mysteriously filled back up. What gives? Could the fill valve be leaking?
    Stampede Central
    is pretty sharp lookin'
    thermocouple /thread
    Hah, that bring back bad memories.
    May 2008
    Wildflower Ranch
    Neo-Liberal Anarchist Mobile
    Pilot light is out causing water to not evaporate. This does not happen with a Cove or Miele. Trust me. I read a wikipedia article on thermodynamics once. - GIT /threadx2
    Beyond, bunch of creme puffs on this board.
    Everything I say is satire.
    Dec 2006
    Nothing worth mentioning.
    Check valve needs a replacin.
    May 2008
    Wildflower Ranch
    Quote Originally Posted by SJW View Post
    Dishwasher needs a replacin.
    fixed.
    Come join @cdnsir 's appliance group buy.
    Check the drain for a plug or drain pump might have something stuck in the impeller blade usually those are the most common issues. Also check the drain hose you might have some gunk built up in there.
    Plus one on pulling the drain impeller/pump and cleaning it out.
    Be careful while you do it though, had the same issue happen but it was a broken chunk of a wine glass that got in that was in there which obviously you don’t want to be feeling around blind with glass in there. Just a tip.
    Quote Originally Posted by bigboom View Post
    I mean I can, but it drains fine, and then fills up like half a day later.
    Fine while it’s running and spinning, but something fucking up the seal allowing it to back flow sounds like a potential issue.
    Also consider where the water is coming from, is it your sink draining into the dishwasher?
    Could also be the fill solenoid (or whatever it’s called), easy to replace. Your water line has positive pressure so if the solenoid isn’t closing it will slowly fill up. Just had to fix that on my last Bosch for a different reason (solenoid cracked and was leaking into pan).
    If it fills up after it drains you might want to take a look at the check valve then.
    Dec 2006
    I've got a dishwasher im about to throw out. Maybe the checkvalve flapper will fit? Frigidaire
    I guess either the drain line check valve or the fill line solenoid valve really has to be the culprit.
    May 2008
    Wildflower Ranch
    Such a waste of perfectly good dish racks. You must come from a rich family.
    Chevy Colorado ZR2
    Clean water - valve
    Dirty water - pipe backing up. Very common these days the solids tends to get stuck and eventually fills the pipe with crud. One case was dog food down the garburetor and expanded in the pipes causing blockage.
    Another issue could be just food particles like peas, sliced almonds, rice getting stuck in the around the impeller area. There's usually a cover you can pop out held with a Torx screw and you can clean past the opening.
    N/A
    Well @ExtraSlow ?
    You guys know I'm not..... Quick, right? Anyway, 99% sure this is the fill valve so just shutting off water supply after each cycle. Work has been mostly busy this week, and heading out of town for a few days with the kids. Will sort it out Sunday probably. Order parts Monday.
    Dec 2006
    https://www.youtube.com/watch?v=Z0YIJQ1jgEI
    May 2009
    G37X
    My Bosch diswasher was doing that, would slowly fill when off unless I shut the water off. Replaced the water inlet valve and now it's fine. Cost ~$50 from Amre Supply. My hose clamp no longer kept enough tension on the hose so I had a bit of a leak but once I put a new hose clamp in the water inlet hose there's been no issues and the dishwasher doesn't fill up anymore. This shows what I replaced on mine. https://www.youtube.com/watch?v=i5nygF7meKQ
    So took it apart Sunday to find part number, because I couldn't figure it out from the dishwasher model number. Amre didn't have my fill valve in stock, but reliable parts did. Picked it up and installed this morning. Running test rinse now to see if I've left any leaks.
    Really simple job for anyone. Hardest part was figuring out which valve I needed. Bosch had used a few.
  1. FS: Maytag 10 Cycle Washer and Admiral Ultima 3 Cycle Dryer
    By Env-Consultant in forum Consumer Electronics
    Latest Threads: 12-13-2014, 04:55 PM
  2. FS: 1 Month Cycle Of Animal Stak, 2 Month Cycle Of Animal Pak
    By Forcefed in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 07-08-2004, 10:48 PM
  3. Over filling oil pan...
    By 01Vortech in forum Mechanical
    Latest Threads: 04-06-2004, 07:47 PM
  4. Who in Calgary does a good job filling windshield cracks?
    By Redlyne_mr2 in forum General Car/Bike Talk
    Latest Threads: 12-13-2003, 11:24 PM
