Originally Posted by
JfuckinC
is there pony walls at all? or is it just framing on slab... I'd say the only issue would be the fact you would need to somehow form pony walls or undercut the existing ones to form deeper ones and footings, then what would you do to temp support your structure? The temp supports would be in the way of new construction unless you could somehow pour around/on them.. That's just my simple mind thinking about it though lol
If you could excavate the perimeter then demolish the slab(and pony walls if applicable) Some how support it, then do it in sections it might work? Then pour the slab later like they do a normal attached garage. Seems like a pile of work compared to jacking it up and filling in the gap.
