Deck Stairs- Help! - Beyond.ca - Car Forums
Results 1 to 5 of 5
Thread: Deck Stairs- Help!
    Default Deck Stairs- Help!
    Alright all of you beyond experts, I need help with some stairs.
    I’ve only ever built stairs perpendicular from the deck, but our new configuration will be slightly different as I built a hot tub pad where the stairs were.
    Essentially I am looking to build the stairs off an angled section of deck, parallel to the house.
    The angle between the house and deck is approx 140deg.
    Question is, how do I build these stairs?
    The stairs pictured are the original stairs I’ve attached for a short term solution.
    Thank you all in advance.
    Nov 2003
    2008 Mercedes Benz C230, 1968 Chevy Impala
    From what I can see, youve attached them to the deck with a few screws on each side?? Likely an accident waiting to happen. You want to hang the stairs with the appropriate stringer bracket. You could also buy metal stringers from HD which can be bolted on through the frame of your deck. That might be the easiest diy option for you as it doesnt appear as though your stairs are a focal point. You just have to measure your height and purchase the corresponding stringers. You could also probably use your existing step decking boards to keep it as inexpensive as possible.
    https://www.homedepot.ca/search?q=stringer#!q=stringer
    1968 Impala: Status: Stored
    1977 Dodge Triple E RV: Sold
    1989 Mercedes Benz 420 SEL: Sold
    2008 Mercedes Benz C230: Cruising
    2000 Bluebird TC2000: Build phase of skoolie project
    2018 Rav4 XLE: New baby friendly daily
    To make it look half decent, need to lift the deck boards, add onto deck to make it square 90 degrees. Then build the steps. Most likely adding another post to the ground to support the weight on the end. Might be able to do so with the railing post.
    I'd use a railing if you have a hot tub. It'll get icy in winter.
    Hack jobber way, build out to 90 corner with plywood, add supports to ground and add the stairs off it.
    This is what I was thinking would need to happen.
    Hot tub access will be directly step in from the deck.
    You wouldn't need that many new boards. Current boards as long as you lift them ok and not rotted can be reused. Just stagger the lengths so you don't get a weird board pattern.
  1. stairs in garage
    By JC522 in forum Home and Garden
    Latest Threads: 08-05-2009, 01:28 PM
  2. FS- BRYDON stairs in two sizes
    By RawB8figure in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 07-24-2008, 08:06 AM
  3. spriral/curved stairs for exterior walkout deck
    By riceboi in forum Real Estate / Finance
    Latest Threads: 05-12-2008, 08:27 AM
  4. Rome stairs: 1 Drunk Celica driver: 0
    By Godfuader in forum Automotive News
    Latest Threads: 06-15-2007, 09:25 AM
  5. Nissan Trial Stairs (WMV video)
    By ThuleAudio in forum Cars, Bikes, Machines
    Latest Threads: 05-05-2005, 09:18 PM
