Help a guy who doesn’t wire move his modem - Beyond.ca - Car Forums
Results 1 to 9 of 9
Thread: Help a guy who doesn’t wire move his modem
    '14 Taco
    Default Help a guy who doesn’t wire move his modem
    Have a wifi modem in my house connected to a coaxial in the living room. Would like it moved to a coaxial that is upstairs.
    Looks like I have two coaxials in my basement that are just cut, so assume one is the one I want..any way for me to tell?
Size:  30.0 KBName:  E2B778DD-4B41-4674-94E0-98C976E92EA2.jpg
    Do I just assume that one of those cut ones should go out to the coaxial in my upstairs den, as there is a coaxial outlet? Any way to tell without just trial and error?
    I have zero zip nada for experience... I think Shaw just chose the coaxial it did in the living room as that’s where the previous home owner was setup. I don’t want to reinvent the wheel, just want to have my wifi closer to computers and ps4
    If you have nothing connected ot the other end - short out the basement coax (shield to core) and then do a continuity test on the other end with a multi meter.
    '14 Taco
    Sorry... what do you mean shield to core? Like I said, I don’t do electronics!
    Jan 2014
    Airdrie
    '16 WRX, '23 CX-50
    Might be the camera, but is the cable on the left flat?
    06 S2000
    Core is the wire in the center. Shielding is the metal weaved cable around the outside. Make them touch, and use a multimeter with resistance testing at the other end to see if it's open or closed.
    My car sounds like shit.
    ^ what he said - you can use a paper clip too (among other metallic objects)
    '14 Taco
    Thanks gents. And then I can just connect the coax to where the current one is, and I can move the router upstairs? Should I just put a connector on the two cut ones, while at it?
    You can leave alone the 1 that you dont need, and just connectorize the one you need.
    '14 Taco
    Got it! Went from like 30 MBPS speed on my PS4 to 100+ by getting it in same room!
  1. Dead guy displayed at his funeral riding his crotch rocket
    By Redlyne_mr2 in forum Automotive News
    Latest Threads: 06-09-2010, 09:29 AM
  2. Automatic car doesn't move until warmed up
    By Ukyo8 in forum Mechanical
    Latest Threads: 02-22-2010, 12:23 AM
  3. fs: Telus MOdem and Wire router/modem
    By brownskind in forum Computer Hardware & Peripherals
    Latest Threads: 09-13-2006, 06:33 PM
