win10 netsh virtual network issues - Beyond.ca - Car Forums
Results 1 to 8 of 8
Thread: win10 netsh virtual network issues
    calgary ab
    4x4
    Default win10 netsh virtual network issues
    Having one of those ongoing issues with win10... Wondering if anyone knows a solution.
    Wifi sharing... Using the icon based setup hotspot setup, it doesn't work - see this is a regular issue on microsoft help forums...
    But it works from command prompt:
    netsh wlan set hostednetwork mode=allow ssid=SSID key=Password
    netsh wlan start hostednetwork
    However after reboots and randomly (daily), the new "virtual network connection" that creates gets stuck... Rather than showing my SSID on the adapter settings - it randomly just shows "identifying..."
    Sometimes I can get it back by running netsh stop and starts. Usual solution is to remove the sharing off the wifi adapter, reboot, run commands above, set sharing up again.
    Don't suppose anyone has an idea why that virtual network gets stuck on identifying? Or is there a way to have it automatically reset rather than doing it manually?
    Thanks in advance
    wifi sharing from a PC? thats something I have not seen a lot. adhoc wifi sure .... but not from a pc
    calgary ab
    4x4
    range extenders didn't work, got tired of throwing money at it. It gets wifi to the other end of the house and that's all that matters.
    that..... sounds like a setup issue with the hardware, or low quality hardware, if a PC can function as a wifi hotspot but a wifi unit cannot.
    calgary ab
    4x4
    Lol, if only you knew how many times I've heard that and that's failed. Pc connects via a alpha networks 2000mw wifi adapter, connected to a 9db external directional antenna.
    That's how I get WiFi to that pc. Yes alpha networks provides bridging function but it takes the speed radically down so I can't watch a show on netflix in the bedroom.
    So connected to the pc and using the microsoft tools that exist to do this - it actually works natively. Except those nightly updates and the occasional drop where for whatever reason it doesn't start up the second network properly.
    But yes I realize I can go spend 340$ on a linksys router to do the same thing...
    Aug 2011
    Strathmore
    2005 Dirtymax
    Quote Originally Posted by AndyL View Post
    Don't need to spend $340 and bridge mode should never slow down a network because your basically putting your modem into a dumb mode if you will and relies on the router/switch you have it being fed into.
    I know you came asking for help and we are trying to get an idea but you really haven't said much about how your network is setup and even the smallest misconfiguration could cause issues elsewhere.
    calgary ab
    4x4
    Network is stock off the shelf shaw bluecurve. The techs who've been here say it is what it is, it's the building - concrete walls.
    Don't really want to reconfig the network, just want the tools in windows to do what they're intended to. yes I realize that's a lot to ask
    a) blue curve units are complete shit unless they are relegated to simple modem duty - any ISP repeater for such unit is essentially garbage piled on top of garbage. You dont need a 300$ asus unit, you probably need an 70$ edge router and a 90$ UNIFI WAP unit.
    b) get a linux PC if you want something that works reliably - no doubt there are systems that can turnkey a windows box into a hot spot!
    c) have a dedicated windows PC that does nothing else - no updates, no reboots, etc.
  1. Replies: 4
    Latest Threads: 11-12-2018, 01:22 PM
  2. FS: Complete RIG!! - HIGH END Desktop DELL i7/32GB RAM/WIN10
    By patek.wis in forum Computer Hardware & Peripherals
    Latest Threads: 03-22-2017, 10:38 AM
  3. Rogers having network issues tonite?
    By ZMan2k2 in forum Computers, Consoles, and other Electronics
    Latest Threads: 05-12-2012, 09:54 AM
  4. Network connectivity issues
    By msommers in forum Computer Help Desk
    Latest Threads: 04-25-2011, 10:21 AM
  5. Issues with Telus on new network
    By msommers in forum Computers, Consoles, and other Electronics
    Latest Threads: 12-22-2009, 10:44 PM
