PC Build Thread - Page 24 - Beyond.ca - Car Forums
Page 24 of 66 FirstFirst ... 14 23 24 25 34 ... LastLast
Results 461 to 480 of 1319
Thread: PC Build Thread
  1. #461
    Stampede Central
    is pretty sharp lookin'
    Did you select the drive to boot from? Hit Del or f2 when the computer hits the bios and check the boot order
    Sometimes it seems to think the RAM is shot, but the same DIMM works on other mobo
    But yes once it makes it past that it doesn't seem to think there's any HDD at all
    And the one it did read my OS drive, it hung up on a flashing underscore
  2. #462
    Mar 2010
    Ioniq 5
    Finished my new build finally. Took way too long to track down the stupid gpu.
    Specs:
    Lian Li Lancool II case
    Laser etched the glass panel (excuse the lighter imperfections, cleaned it after and they all came off, this was right off the laser)
    Ryzen 5900x, Asus TUF 3060 ti, 4x16gb gskill neo 3600CL16 ram, 500gb 970 plus ssd, 8tb WD drive, 10tb Seagate drive
    Overall pretty happy with it and looks pretty sweet with the lights lighting up the etching. Hard to take pictures of though as it reflects the camera light
  3. #463
    May 2008
    Wildflower Ranch
    Neo-Liberal Anarchist Mobile
    That is nice! I wish I could hunt down a 5900x.
    Beyond, bunch of creme puffs on this board.
    Everything I say is satire.
  4. #464
    Oct 2009
    rally pig
    BIOS detects the RAM and drives then?
    could be a couple of things, have you tried updating the BIOS?
    have you tried changing the boot mode?
    i would create a windows 10 usb installer and start from scratch.
    https://www.microsoft.com/en-ca/soft...d/windows10ISO
  5. #465
    Stampede Central
    zero clue how to update a P8Z68-V PRO
    Also... boot mode?
  6. #466
    Mar 2010
    Specs:
    looks good!!
  7. #467
    Apr 2003
    00 Honda CR-V, 02 IS300
    Amazon just delivered. Will get it installed later, will look much better in please of the NH-L12S thats in there right now. Kinda wishing now I had gotten a black NR200P instead of the white one so everything would be blacked out completely.
  8. #468
    Mar 2010
    Finished my build a couple weeks ago.Name:  PXL_20201228_203140448.jpg
  9. #469
    May 2008
    Wildflower Ranch
    Quote Originally Posted by CivicDXR View Post
    I am shoving a U12A in mine because a HDD mounted behind the PSU would probably be too tight for a side mount cooler.
  10. #470
    May 2008
    Wildflower Ranch
    I am just waiting for a Zen 3 processor and maybe an SF750 before I complete my new build.
    Here's a very very similar build to what I currently have from the end of March this year. Adding tax, it comes to $2,265. 70% of that per taemo's rule comes out to $1,584. You guys think that's fair value?
    Differences:
    - My unit has a 3600x vs 3600 above.
    - MSI Evoke OC 5700XT vs Asus 5700XT
    - EVGA G6 650 vs EVGA 650 GM
    - Gigabyte B450 Aorus M + wifi card vs B450 AORUS Pro Wifi
    - Win 10 Pro vs Win 10 Home
    - 3 extra RGB fans
  11. #471
    Sep 2003
    Defender, Allroad
    It's hard to say what people will pay for computer parts right now because of the supply issues. I sold a 1070 for $300 yesterday. It doesn't make any sense to me...
  12. #472
    May 2008
    Wildflower Ranch
    I don't want to carry two systems so I prefer to sell to someone here rather than a kijiji random.
  13. #473
    Quote Originally Posted by The_Rural_Juror View Post
    Differences:
    - 3 extra RGB fans
    The 970 EVO Plus is better and cheaper than the WD Black SSD:
    https://www.bestbuy.ca/en-ca/product...0b-am/13815644
    Also 3200 CL16 is pretty slow for Ryzen, if you want 3200 look for CL14 otherwise 3600 CL16 is the sweet spot for performance/value. If you're willing to spend $319, this is cheaper and a much better kit stock (Samsung B-die) and allows for both easy OC (if desired) and/or expansion to 64GB if ever needed in the future:
    https://www.newegg.ca/g-skill-32gb-2...vQK6zPBTt3AhrQ
  14. #474
    May 2008
    Wildflower Ranch
    I can't find any of the 2 x 32gb ram in 3600 cl16. Only two slots in the mitx board.
    That's also my old machine. I am not sure if the Evo Plus was available back then. New one will have an SN850 plus a Sabrent Rocket.
    Mom won't let me complete my new build until I sell this. Grrarfgh.
  15. #475
    Apr 2003
    U9S installed. Wanted to do it yesterday, but realized the fan splitter didnt show with the cooler and second fan. Showed up this morning, so I tossed it in. First installed with cooler blowing out of the case as an exhaust. CPU temps went way high under load (heaven and CPUZ stress test running). Figured due to the hot air already inside the case from the GPU going through the cooler to make it hotter. Flipped the fans around, and much better. Now I know my processor doesn't run hot at all being a Ryzen 3 3100 65W TDP, but I went from 72C max at full load with the old L12S cooler (CPU overclocked to 3.9GHz) to 68C at full load (bumped up overclock to 4.1GHz). Quite surprised that even after turning up the CPU the temps still dropped. Guess I'm just lining up for a jump to a Ryzen 5 or 7 eventually, but I dont really need it at this point. Also cleaned up and rerouted the cables a little better just for my own OCD reasons.
    Interesting note though: I guess the tempered glass changes things because the CPU temps were also exactly the same with the mesh side panel intead of the TG panel whether the CPU cooler fans were set to intake or exhaust.
  16. #476
    May 2008
    Wildflower Ranch
    Looks great!
  17. #477
    Apr 2003
    Thanks! Now I just gotta decide if I want to fill the PSU cage face with a hard drive, or maybe a mount small LCD as a monitor display similar to what sl888 did with his Nexus tablet.
    https://www.reddit.com/r/sffpc/comme...uild_and_took/
  18. #478
    Sep 2005
    2011 lexus is250 awd
    Differences:
    - 3 extra RGB fans
    why are you selling this again?
  19. #479
    May 2008
    Wildflower Ranch
    You a-holes got me into the sff thing, I want more coars, and most of the stuff doesn't transfer over.
  20. #480
    Mar 2009
    Silverado
    These builds make me embarrassed lol. I added another ssd yesterday. Up to 3 now totaling 2 tb. Added two 120mm fans, a second front inlet fan and a pull fan for my cpu cooler. Running about 5c cooler which is damn suprising.
  1. Pre build or build out a pc? Need to upgrade my home desktop
    By cycosis in forum Computer Help Desk
    Latest Threads: 02-28-2020, 01:16 PM
  2. Replies: 87
  3. 92 ''Just a Civic'' Build/Story Thread
    By Sparx in forum The Garage
    Latest Threads: 04-28-2010, 05:21 PM
  4. My second silvia build thread.
    By CivicTunr in forum Nissan 240sx / Silvia Owners
    Latest Threads: 08-07-2008, 08:53 PM
  5. Silvia build thread
    Latest Threads: 04-11-2008, 08:08 PM
Tags for this Thread
