Well I'm a moron! Plugged PCI-E power into CPU power - Beyond.ca - Car Forums
Results 1 to 7 of 7
Thread: Well I'm a moron! Plugged PCI-E power into CPU power
    Mar 2007
    Default Well I'm a moron! Plugged PCI-E power into CPU power
    Built many of PC's before, and just happened to make the most bone headed move ever. I'll blame it on building tonight dead tired.
    I plugged PCI-E power into CPU power... I have no idea how I even got the cable in as they are keyed differently, but somehow I did. Fucking rookie shit.
    PSU clicked (Gigabyte GP-P750GM) but nothing powered. Didn't even get a fan or anything to light up. Trouble shooted for a bit, a couple more attempted start ups to the same thing. Then fucking lost it when I figured out what I did. Fixed it, booted fine, installed windows. Everything is working fine, no hang ups.
    Any chance I caused any damage that I might not notice right now?
    2015 CLS63s AMG Coupe
    Quote Originally Posted by Spoons View Post
    No way to really tell...
    Things to keep an eye out for:
    1) Check the capacitors on the mobo, look for any that may have blown.
    2) Keep an eye on stability (BSODs, etc.)
    3) I don't know if this is relevant, but run a memtest. This will create a decent load and make sure memory modules weren't fried
    4) Check to make sure the Mobo is keeping BIOS time after power is disconnected for 5 minutes.
    Be happy it booted, we all make mistakes every once in a while!
    Sig was pwned by Moderator!
    click for larger version
    You likely dead shorted and the PSU saved you with it's short circuit protection... Otherwise yeah you plugged power into the ground plane which isn't great but if it started up you're likely Ok.
    With the short protections on board and PSUs (esp if you have a good one), its likely no harm was done. You can try something like heavy load to see if running everything at 100% is stable.
    Mar 2009
    '18 Murano
    Quote Originally Posted by mazdavirgin View Post
    99% this. I'd stop worrying about it and count yourself lucky.
    Mar 2007
    Very lucky indeed! As soon as I realized my mistake I thought I was done for.
    Thanks you all for the reassurance!
    If you have a modern PSU you should be fine. Just do a few tests when you get everything back up and running.
  1. Replies: 17
    Latest Threads: 11-18-2010, 05:17 PM
  2. Computer boots up as soon as it's plugged in.
    By em2ab in forum Computers, Consoles, and other Electronics
    Latest Threads: 08-23-2009, 06:37 PM
  3. Car plugged in, but still won't start
    By al-ti2d in forum Mechanical
    Latest Threads: 12-16-2008, 12:31 PM
  4. Has anyone with a Shaw HD PVR (6416) plugged in an external HD to record?
    By Pacman in forum Computers, Consoles, and other Electronics
    Latest Threads: 07-08-2008, 10:19 AM
