Just as the title mentions;
How do I prevent Win10, from utilizing cellular hotspot, via iPhone USB ?
I have a wired/cat connection, that more that does the job. I'd like to connect my iPhone via USB to charge/transfer only.
Thanks!
Thanks!
Originally posted by sputnik
Cell providers are the next Blockbuster video stores.
Settings>personal hotspot>Allow others to join>off
Do you mean on my cell phone ?This quote is hidden because you are ignoring this member. Show Quote
I don’t want to that off. I use that function.
It’s why I want to limit my pc from taking the connection.
Then tell your computer to forget the wifi connectionThis quote is hidden because you are ignoring this member. Show Quote
When you plug your phone into the computer don’t click yes on the “allow this device to connect” message.
Also you can disable the network adapter in windows settings.
You want it on all the time? Why not just turn it on when you want to tether and turn it off when you don't? that's what i do. Its also more secure and might even save a tiny bit of battery since your phone won't always be broadcasting an SSID connection.This quote is hidden because you are ignoring this member. Show Quote
In windows, under connections, isn't there settings on each connection? You can set that one as "metered connection" which saves some data, or you can just turn off data on that connection completely, I think.
Or, much smarter like mentioned above, turn off the hotspot function on your phone when you aren't using it. Better security and battery life.
under W10 wifi settings (lower right corner, wifi icon) - right click on the hotspot network your phone is broadcasting and select 'FORGET' , or DISCONNECT and then deselect CONNECT AUTOMATICALLY.
alternately, you can turn off W10 wifi manually altogether (temporarily) on the same icon as well as you are hard wired
It's not WiFI. The iPhone's Lightning connection is connection to the USB connection on my pc, and broadcasting the connection from the iPhone's LTE to the PC.This quote is hidden because you are ignoring this member. Show Quote
That appears to have done it, and am humbled.This quote is hidden because you are ignoring this member. Show Quote
Thanks
