Transfer case issue in 4 low - 2004 GMC 2500 - Beyond.ca - Car Forums
Results 1 to 7 of 7
Thread: Transfer case issue in 4 low - 2004 GMC 2500
    2008 Z06
    Default Transfer case issue in 4 low - 2004 GMC 2500
    I recently changed fluids in my 2004 GMC 2500HD. Trans, diffs, transfer case (Dex 3).
    Today I was plowing in 4 low, and started to hear an odd noise from the transfer case.
    - 2wd and 4 high, no issue.
    - When switching into 4 low, put it in neutral, push 4 low button, light blinks then goes solid. Still no noise/issue.
    - When changing from neutral to drive, a noise starts, like the gears in the transfer case are hunting to mesh together. Now, it won't actually go into 4 low. 4 high still works fine.
    Any thoughts before I visit a trans shop?
    calgary ab
    4x4
    Heated shop, let it warm up/dry off try again. One of the pushbuttons is notorious for it...
    The gay man cruiser I get stuck plowing with on occasion does it too - I just plow in 4hi. It's survived 8 seasons now...
    2008 Z06
    You're saying a common issue is related to the 4 low button, and moisture?
    Aug 2011
    Strathmore
    2005 Dirtymax
    Quote Originally Posted by Ekliptix View Post
    The actuator motor on the transfer case are known to fail. It made need to be swapped.
    https://www.youtube.com/watch?v=THgtXb-RI5o
    calgary ab
    4x4
    I can't remember the mechanics explanation - not the same as the old 1st gen s10 issue with the axle disconnect but yeah, let it warm up dry out and it goes back to normal.
    2008 Z06
    Interesting, thank you. Since it can go into 4 high without issue, would that suggest the actuator motor is working fine?
    Mar 2005
    Foothills County
    is faster than yours
    Just curious why you're plowing in 4-low? Can't say I've ever had a reason to do that.
  1. Issue with Jeep JK transfer case
    By Loose in forum Trucks, 4x4 and Offroading Zone
    Latest Threads: 11-22-2013, 08:40 PM
  2. Maximum amount to transfer via e-transfer?
    By nzwasp in forum Real Estate / Finance
    Latest Threads: 05-29-2013, 10:56 AM
  3. To Transfer or Not To Transfer?
    By dj_patm in forum Campus Chat
    Latest Threads: 12-22-2011, 02:34 PM
  4. FS: 2004 GMC 2500 4x4 Blue
    By leutyc in forum Cars, Trucks, Motorbikes, and Trailers
    Latest Threads: 03-20-2008, 04:36 PM
  5. transfer credit part of program transfer GPA
    By boostless in forum Campus Chat
    Latest Threads: 04-07-2007, 05:36 PM
