Remote Starter Gurus - Beyond.ca - Car Forums
Results 1 to 4 of 4
Thread: Remote Starter Gurus
    Calgarian Living in Edmonton
    Default Remote Starter Gurus
    We got any remote starter gurus in here?
    Picked up a 2008 Toyota Highlander Sport as a winter beater from work as a trade in by a customer. Found out it has a Prostart/Autostart remote starter installed in it from Canadian Tire. But oddly, when I bought it, the antenna was disconnected and the key fob although it has LCD damage from battery acid leaking, it still works both were in center console.
    Plugged in antenna and light blinks blue
    Pulled apart the dash and found the remote starter module and a Idatalink Blade immobilizer bypass. I couldn't find a hoodpin to do a re-program so looks like they wired it up without hoodpin. Anyways, I tried to get it started but it just cranks and wont start. But when I have the key in the ignition, the remote starter works. But I dont wanna mess with programming the module again since I'm no expert in this field and then my car doesnt start.
    How to tell if the immobilizer is shot or if it just needs to be programmed again? If I program it wrong, will it fubar/brick the immbolizer?
    Thanks in advance *too cheap to buy another immobilizer so hoping this one still works*
    Originally posted by GTS Jeff
    2020 Subaru Forester Sport
    Sounds like the immobilizer bypass is messed or needs to be tuned again. I would just find the model number of the immobilizer and find the guide on now to program it or check functionality. I know when I have done these in the past there were lights to indicate if things are working, and programming was rather simple. It won't mess up your car.
    If it remote starts with the key in ignition, that means its working correct?? Just wont start without key there.
    I bet the hood pin wire is loose somewhere. Probably grounded
    And needs to be open for vehicle to start. Find the wire then get a hood pin to fix properly. EBay or aliexpress.
    https://m.aliexpress.com/item/400033...0Q90.jpg_.webp
    Also check ebrake switch wire.
  1. Replies: 0
    Latest Threads: 11-29-2008, 11:57 AM
  2. remote starter 290ic reprogram remote
    By RUSSINAK in forum Trucks, 4x4 and Offroading Zone
    Latest Threads: 12-28-2006, 12:10 AM
  3. Discontinued remote starter- need new remote
    By Bekiden in forum In Car Entertainment / Electronics
    Latest Threads: 10-13-2005, 05:35 PM
  4. Remote starter remote?
    By 3G in forum General
    Latest Threads: 12-16-2004, 01:01 AM
  5. Remote Car Starter (Manual Tranny)
    By SpecCRX in forum Mechanical
    Latest Threads: 10-16-2002, 12:26 AM
