LF someone good with a solder iron, and is readily available today or tomorrow - Beyond.ca - Car Forums
Results 1 to 11 of 11
Thread: LF someone good with a solder iron, and is readily available today or tomorrow
    Only 15min from Aspen!
    Nothing interesting anymore
    Default LF someone good with a solder iron, and is readily available today or tomorrow
    Need a couple of relays replaced on my hot tub circuit board. I have the relays in-hand, but won't remove the board until I find someone who can do it. Can't keep power off the tub for too long, so I need someone who can do it fairly quickly after I take it out.
    See circle in pic.
    Name:  Balboa VS500Z.jpg
    Dec 2006
    Nothing worth mentioning.
    I just went through this. I ended up replacing the whole board.
    you need a specialized soldering set (suckers, etc.) with a microscope for some of the smaller things on that board - if it was just the wires I could do it right now
    Mar 2008
    Yea that's not a job you do with a soldering iron without a solder sucker. You could get some tin foil, mask off the area, and use a heat gun.
    Yeah, wiring I can do myself. I've also done some circuit board building, but never removing components, even though I have a sucker. This isn't the one to try myself because if I fuck it up, my tub going to freeze solid.
    Quote Originally Posted by SJW View Post
    Did you try the relays first? I know for sure the lower one is toast. I've been lightly tapping it to get unstuck when it stops heating.
    Dec 2006
    They couldn’t Diagnose. Nor could I.
    I just had a leaking hose. Hot tubs are a pain but so worth it.
    buy the board and then attempt fixing the old board - if it works for 30 days (or whatever the return time frame is) then you have just paid for shipping as a contingency measure - but also have a functional HT
    Aug 2004
    If you can drop it off I can give it a go. I have the tools required. Sucker, copper braid if required solder etc...
    SE calgary. Deer Ridge.
    2011 Ram 1500 QC Sport
    2017 Jeep Cherokee Limited
    Aug 2004
    See circle in pic.
    Do you have a pic of the other side ?
    Aug 2004
    That's the one. His trick didn't work though because the relay is sticking. Pm'ing you.
  1. LF - Someone to Solder
    By RawB8figure in forum Computers, Consoles, and other Electronics
    Latest Threads: 06-15-2014, 05:27 PM
  2. LF: someone to solder
    By G-ZUS in forum Computers, Consoles, and other Electronics
    Latest Threads: 04-05-2014, 09:29 PM
  3. LF: Someone that can solder a piece to a motherboard
    By PAV in forum Computer Hardware & Peripherals
    Latest Threads: 12-24-2013, 05:36 PM
  4. Replies: 3
    Latest Threads: 08-02-2013, 10:58 AM
  5. LF: someone with awesome soldering skills (1 solder = $20)
    By canadian_hustla in forum Computers, Consoles, and other Electronics
    Latest Threads: 03-17-2012, 06:27 PM
