Lugs Loosening Off - Beyond.ca - Car Forums
Results 1 to 20 of 34
Thread: Lugs Loosening Off
    Default Lugs Loosening Off
    Bit of an odd one here - hoping others may have some insight.
    Summer 2019 I randomly noticed some noise from the front drivers side of my WRX. Pulled into a parking lot and noticed that 3 of my lugs were loose, but only on that one wheel and my locking lug was still torqued properly. I change over my own tires by hand and torque the wheels with a torque wrench so I know they were torqued down and rechecked at that torque properly. Chalked it up to them being tampered with given that all other wheels were still solid and the locker was tight.
    Fast forward to tonight, I'm driving and notice a similar sound. Pull into a parking lot and sure enough, lugs on my drivers side front wheel are loose. This time the locker is also loose though. All other wheels still torqued properly.
    Is this a sign of needing to get the studs replaced? Bad wheel nuts? Something else I'm not thinking of?
    Dec 2006
    Nothing worth mentioning.
    Something is worn. Threads rely on friction from torque. If it’s stretched perhaps you’re not getting what you need. Just a guess. At the very least replace the nuts.
    Do you ensure that the nuts are thoroughly snug, like probably 50+ ft-lb tight with the wheel in the air before you let the car down to finish with the torque wrench?
    Because I've seen many people achieve 80 ft-lb of torque because the wheel was barely on when they dropped the weight of the car onto it and the wheel went cockeyed a bit which means the flange face isn't flush on the hub so the torque doesn't mean anything.
    Let me know if that gibberish explanation makes sense.
    Calgarian Living in Edmonton
    Are the wheels aftermarket? If yes, do you have the correct type of lugs for said aftermarket wheels?
    Originally posted by GTS Jeff
    Beaumont
    Touareg, Cayenne, 944s
    Quote Originally Posted by dj_rice View Post
    This. There are different shapes of lugs and you need to match the wheel to the lug ie. cone, ball, flat.
    Quote Originally Posted by BrknFngrs View Post
    were the threads dry and clean when you torqued them?
    Jul 2006
    Victoria Park
    Loctite Red. Problem solved.
    /s
    Dec 2006
    /s
    If you're gonna go red may as well go green.
    Jul 2006
    Victoria Park
    Quote Originally Posted by SJW View Post
    Hey hey hey now. You know what they say...
    Never go full re-...
    Have you been to BC lately?
    Otherwise, replacing lug studs isn't too hard to do.
    The sacrificial lug nut method is easiest and use a torch helps.
    This is where I'm leaning as well, but wonder if damage or worn studs would just wear out new lugs. Safer to change both at once? Also seems odd its only affecting this one wheel - though the same lugs do go on the same wheel each time as I change them over one at a time.
    Process wise I think I should be safe. Jack lowered so the wheel is just touching the ground to reduce spin, but vehicle weight isn't on the tire fully. Torqued to spec. Drive a few days around town - retorque to spec with weight on the car?
    Stock WRX wheels for winter, STI BBS's wheel for summer (believe they're factory but not 100% sure). Use the same nuts for both sets of wheels and the locker is also the factory Subaru one.
    Believe so, don't recall any obvious damage either, but do recall a few lugs being tougher to start by hand.
    /s
    Haha - calling this "Plan C"
    - - - Updated - - -
    Have been staying clear of BC! And agreed, haven't done it before but looks straightforward.
    Booger a weld on the end bro
    X5D, Fiesta ST
    I was going to suggest upping the torque by 5lb/ft but then I saw Subaru. Don’t do that, Subaru studs are the softest garbage known to man.
    Quote Originally Posted by Twin_Cam_Turbo View Post
    Hmm wonder if maybe they were overtightened at some point in their life and the studs are now shot. Seems to add weight to the worn out theory.
    Only 15min from Aspen!
    Nothing interesting anymore
    Have you taken the wheel off after you found it loose? Maybe there's some debris between the hub and wheel.
    Hoping to track down studs/lugs and then pop the wheel off to take a look. Figure I may as well have them handy when I pull the wheel off.
    Haven’t had mating issues with the hub and wheel before but will definitely take a look at that too.
    I was going to suggest upping the torque by 5lb/ft.
    How many extra guh-guh-guh's is that on the impact gun?
    Asking for the Costco Tire installers.
    May 2008
    One more, far out there thought. If you're not sure if the rim is aftermarket, does it have a hub centric ring on it? If so, I've seen those slip out during tire changes then get crushed when remounting. I guess you could also swap the lugs around and see if the same thing still happens. At least you'd rule out those specific lugs.
    Yeah there are definitely a lot of things that can be contributing to you issue, many touched on above.
    Stretched studs will usually present while torquing. If you find that they just seem to not be reaching torque when it feels like it should be there, that can be a good indicator the studs are fuggered.
    Wrong lugs for the rims can be an issue, but it sounds like you are saying both are OEM wheels with OEM lugs so if that is the case I am doubtful this is the issue.
    The hub and mating surfaces being corroded and/or dirty can cause an issue like this but it should be easily identifiable. You might also check the lug seating area on the wheel as well to see if there is corrosion there.
    Is your torque wrench out of calibration? If it is torquing light this could happen as well but really, one would figure it would be on all wheels and not a single wheel if this was the case.
    I have seen all kinds of weird stuff like people not realizing a hub-centric ring is still on the car switching from aftermarket to stock wheels, wrong bolt patterns that while out slightly still fit over the studs, asshole neighbours (or idiot friends) fucking with a person, and all kinds of stuff over the years, but usually it is something simple. Just start at the beginning and remove the wheels from the car, thoroughly clean and check everything is correct, reinstall the wheel on the car making sure to use proper torque sequencing without over-tightening, try to avoid having to put the weight of the vehicle on the tire and wheel while tightening and retorque more than once in a case like this. If you notice everything is staying tight after multiple re-torques you are probably good, but if every time you put a wrench on it, one or two or more of the nuts always seem to need a little extra, and you are certain everything else is proper, if it was my car I am going to move on replacing the studs and lugs.
    Was able to get the car jacked up and took the wheel off over the weekend - definitely the studs that are damaged. Not too sure what caused it but there is a section on a couple of studs where the threads are entirely gone, looks almost like unthreaded metal stock for 1/32-1/16". Was going to swap the studs over while I had the wheel off, but the bolts holding the caliper are on pretty corroded - going to put in a few calls to shops this morning instead. Appreciate everyones input in troubleshooting here
  1. Stabilizer link keeps loosening
    By G-ZUS in forum Mechanical
    Latest Threads: 05-27-2011, 05:08 PM
  2. FS: Tuner Lugs WTB: Lugs WTB: EVO Rotors
    By pathfinder in forum Automotive Parts [Wheels/Tires]
    Latest Threads: 02-28-2010, 07:23 PM
  3. loosening screws and bolts
    By Speed_69 in forum General Car/Bike Talk
    Latest Threads: 02-28-2005, 01:31 AM
  4. Anyone need lugs?
    By szw in forum Automotive Parts
    Latest Threads: 05-20-2003, 02:09 PM
  5. Having a hard time looking for black wheel lugs.
    By Hollywood in forum Performance Modifications
    Latest Threads: 03-30-2003, 07:21 PM
