CO meter in garage? - Beyond.ca - Car Forums
Results 1 to 11 of 11
Thread: CO meter in garage?
    Thaco's Avatar
    Oct 2004
    Rage2
    Default CO meter in garage?
    So i am gonna be moving soon and will finally have a garage, i plan to do some work in there but it's (attached) unheated right now and was gonna use one of those kerosene jet heaters until i can get a proper gas heater installed...
    I'd like it to be as efficient as possible so keeping the door closed as much as i can to retain heat, but still open enough to not die.... Has anybody installed a CO2 meter/sensor in their garage for this purpose? figured somebody has had to have done this and it's better than guessing.
    Wondering what kind of unit someone would use for this.
    User title molested by Rage2.
    ^^ Fact Checked
    Aug 2011
    Strathmore
    2005 Dirtymax
    I just grabbed one off Amazon.
    Can I ask why kerosene though? I was using that for awhile but the smell was gross so went to propane.
    Aug 2003
    Medicine Hat, AB
    It’s a CO meter and it would be a good idea regardless.
    Running a jet heater without ventilation sounds like a bad idea to me. Anything that combusts hydrocarbons will produce CO. I’d stick with electric.
    Thaco's Avatar
    Oct 2004
    Rage2
    just because they're cheap at PA or CT or something, just to get me by until the spring
    - - - Updated - - -
    Yeah that's why it'd just be temp and i want to take this precaution, anything electric you need 220v for and that's also not really an option immediately either.
    ^^ Fact Checked
    Aug 2011
    Strathmore
    2005 Dirtymax
    - - - Updated - - -
    Yeah that's why it'd just be temp and i want to take this precaution, anything electric you need 220v for and that's also not really an option immediately.
    Find of these used or new https://www.princessauto.com/en/3000...t/PA0008945024 and they put out a ton of heat really fast.
    Thaco's Avatar
    Oct 2004
    Rage2
    i'll look in to that, figured propane would be fairly expensive for the gas, given it's just bbq tanks
    ^^ Fact Checked
    Kerosene heaters are gross smelling. Propane, or even better 120V electric.
    ** Note your original post says CO2 when you mean CO **
    Go for it, but use propane.
    My friend did this for years and surprisingly, the CO monitor never alarmed. Very little is produced and if it's a big space, the solution to pollution is dilution.
    *not engineering advise...
    Thaco's Avatar
    Oct 2004
    Rage2
    yeah i fixed it but beyond doesnt update the title
    - - - Updated - - -
    Ideally i'd got electric but 220v would be needed for anything even remotely good enough to heat the garage, and likely quite expensive compared to gas options. Still weighting the options as far as what to use for the actual heat source, just curious about CO detectors in the garage, ideally one with a display so i can see the actual level.
    ^^ Fact Checked
    Beaumont
    Touareg, Cayenne, 944s
    I use one in my garage, but it does go off when I fire up my old 944 and let it idle in the garage for more than a few seconds. Never any trouble with more modern cars, but it's also a cumulative sensor so it doesn't go off for a while after it starts detecting CO. I'll go for a drive and my wife will text me freaking out that the alarm is going in the garage.
    Thaco's Avatar
    Oct 2004
    Rage2
    Quote Originally Posted by JustinL View Post
    yeah that's kinda what i was thinking, hoping i could find one with a programmable alarm, i am sure there's a difference between not acceptable/catch a leak early in a house (where people may be sleeping) vs not acceptable for a short time in a shop.
    ^^ Fact Checked
  1. FS: 5,500 Rounds of Pellet Gun ammo. 61 CO2's
    By Ben in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 07-21-2006, 06:07 PM
  2. fs crossman 1008 repatair CO2 pellet gun
    By civicrider in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 02-06-2004, 10:49 AM
  3. FS: Walther Co2 Air Pistol *SOLD*
    By Fluidic in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 02-01-2004, 02:59 AM
  4. CO2 Canisters
    By BigBanana in forum General
    Latest Threads: 01-02-2004, 08:33 PM
  5. FS: CO2 Air Rifles + Pellets + CO2 gas
    By Superesc in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 08-04-2003, 12:34 PM
