Is a heatpump setup viable in Alberta for heat in the winter?
Is there a reason heat pumps aren't more common vs furnace/radiant heat?
My limited reading tells me a heatpump setup is one of the most efficient ways to heat a home (I suppose solar thermal is better if you are situated to properly use it).
So ELI5 me heatpump setups, and why they are/are not good for Alberta.
