PC/speakers issue...Maybe wiring? - Beyond.ca - Car Forums
Results 1 to 6 of 6
Thread: PC/speakers issue...Maybe wiring?
    Nov 2005
    A Slow Car
    Default PC/speakers issue...Maybe wiring?
    Gotta real weird issue with my pc and ceiling speakers.
    My bedroom tv as a mini pc hooked up to it and every time we shut the lights or the bathroom fan off, the tv screen goes black for few seconds and comes back and makes this weird noise. When i turn off the tv and turn it back on then it's good again.
    Also, there's a loud static coming from my ceiling speakers downstairs and in the bonus room when nothing is playing.
    I appreciate any advice. Thanks.
    “Straight roads are for fast cars, turns are for fast drivers.”
    Started happening out of the blue for no apparent reason?
    Jun 2004
    21 CX5 GT Turbo
    Quote Originally Posted by R!zz0 View Post
    Is there a timer on the bathroom fan, and do you have a dimmer on the lights? And those bedroom lights do you have LED bulbs?
    Nov 2005
    A Slow Car
    Yes just of the blue. Can't figure it out.
    Quote Originally Posted by BigDL View Post
    No timer, no dimmer and yes all the lights are LED bulbs.
    Jul 2007
    Is the TV and mini pc plugged into a power bar?
    For the ceiling speakers, check the grounding/wires on the amplifier. Static usually refers to interference/noise being picked up by speakers.
    If you haven't changed anything and the AC wiring is still good then my money is on the internal power supply of the TV being on it's way out. When you disconnect a load on a circuit you cause a spike in noise which feeds back into the other devices. Generally the power supply if designed properly will filter this out. The fan motor would be especially bad for this for reasons I won't bore you with...
  1. RAM 2500 - CV Joint Issue (maybe?)
    By syscal in forum Trucks, 4x4 and Offroading Zone
    Latest Threads: 04-27-2015, 09:49 PM
  2. LF sr20det mechanic (wiring issue)
    By skyfx in forum Mechanical
    Latest Threads: 11-15-2009, 07:14 PM
  3. Lowered s13 wiring issue
    By RZRSHARP_SVX in forum Nissan 240sx / Silvia Owners
    Latest Threads: 05-09-2008, 09:58 PM
  4. Wiring Issue
    By slaya15 in forum In Car Entertainment / Electronics
    Latest Threads: 04-24-2004, 09:50 PM
  5. WTB: CD Deck, Maybe some speakers
    By 350hp_or_Bust in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 02-18-2003, 11:15 PM
