Garden irrigation set-ups with IBC totes? - Beyond.ca - Car Forums
Results 1 to 10 of 10
Thread: Garden irrigation set-ups with IBC totes?
    '91 NA1 ADVAN'D
    Default Garden irrigation set-ups with IBC totes?
    So folks, just out of curiosity, who's using IBC totes to collect rainwater for irrigation purposes in the city?
    Are the fittings to work standard pipe thread? Would like to set up a gravity feed irrigation system and adapt the IBC tote outlet valve to fit on a garden hose? Alternatively, thinking of setting up a water misting system based on a timer using a gravity feed instead of a pump.
    I think a mister will require more pressure than most gravity-feed systems can provide.
    Lee valley has low flow irrigation parts. Not the cheapest source, but they make it easy.
    '91 NA1 ADVAN'D
    Thanks ExtraSlow, yeah the misting irrigation will definitely take more pressure. I don't think I could elevate the tote high enough off the ground safely to create enough pressure through potential energy to get the misting system to be effective.
    Aug 2007
    dad van
    Most of the IBC's I have seen are a male 2" ish camlock fitting. shouldn't be to hard to find the parts at princess auto to step that down to 3/4" for a garden hose.
    '91 NA1 ADVAN'D
    Thanks for the info guys.
    Curious what people are using to elevate IBC totes? Looking to create a gravity feed irrigation storage system and want to make sure it's going to be sturdy enough to bring the tote to height. Was thinking of using cinderblocks.
    I think most people just buy real estate with a hill.
    Cinder locks would be best.
    I tried wood pallets once and totally filled, I ended up collapsing the pallets.
    I gave up on the setup because no pressure and algae kept growing and plugging the outlet.
    Thought about a small pump to feed the water. That would work and you'd still be saving because water is expensive.
    '91 NA1 ADVAN'D
    @mr2mike - Yeah, thinking cinderblocks as well. I have a metal pallet I was going to set the entire IBC tote w/cage onto. To combat the algae issue, going to use a tarp to cover the tote except for the hole for the water to go in.
    Jun 1987
    SK
    Fit Dugan Signature (2016)
    There should be a tax on collecting rainwater.
    Originally posted by SJW
    Originally posted by snowcat
    ^^ Fact Checked
    [email protected]
    Maybe she can quietly amend to add it.
  1. FS: Brand New Never Used Michelin Premium Tire Totes / Bags
    By ????? in forum Automotive Parts [Wheels/Tires]
    Latest Threads: 11-21-2014, 08:21 PM
  2. Tire bags (or tire totes)
    By Modelexis in forum Wheel and Tire Discussion
    Latest Threads: 12-28-2010, 08:41 PM
  3. UPS question, UPS employees come an look
    By bennyhanna in forum General
    Latest Threads: 05-25-2006, 05:45 PM
  4. Landscaping/Irrigation
    By Kirbs17 in forum Careers
    Latest Threads: 12-01-2004, 06:23 PM
