Odd question, I'm building a garage and the guy doing the excavation discovered my neighbor has a trenched power line going from their property, onto mine, then back into theirs for their shed
Is this allowed?
Is this allowed?
Sig nuked by mod.
Probably not. Check your title.
like is it kinda wandering across the property line? or cutting a corner?
Either way, i don't think this is allowed haha..
If the owner during the time the power line was trenched in allowed it, then yes. It's an easement. Check the title.This quote is hidden because you are ignoring this member. Show Quote
If your place a weird shape or something, or does his zigzag onto your property and than back off? Or is it near the property line?
I'd think that it's more normal to feed secondary buildings with lines that stay inside the same property. No idea what the laws say about it. I mean, you should be allowed to trench all around on your property with impunity, I'd think unless there is an easement or anything. Did you ask the neighbor?
No weird shape, not cutting a corner, it’s a good 1.5’ inside my property line running parallel
Nothing on the title has this information that I’ve seen
Other problem it’s in the direct way of the garage pad
Sig nuked by mod.
Maybe I'm missing something, but... who cares? If it's not causing you problems, just bury it and forget about it.
if it's not on title, I think you can force the neighbor to move it. you really should start with talking to them though, as I suspect any legal means of forcing them would take a year or more . . .
Fuck it. Cut it.This quote is hidden because you are ignoring this member. Show Quote
I think most excavations companies would be hesitant to dig up a live electrical line on purpose.
recycle the portion on your lot, cover part of the garage build $$
If it’s in the way, tell him to move it or cut it.
If it's only 1.5' into your property, you won't end up pouring a pad over it, as minimum setback requirements are 2' (in calgary, at least), but I guess it's likely still in the way while you prep the pad and pour your footing.This quote is hidden because you are ignoring this member. Show Quote
Honestly, it's probably the BEST time for your neighbour to learn of this bad news, since you already have a machine on site. Perhaps your neighbour can strike a deal to get your excavator guy to trench out a more appropriate place in their yard?
Unless Midnapore for some insane reason.This quote is hidden because you are ignoring this member. Show Quote
?This quote is hidden because you are ignoring this member. Show Quote
It may have been buried without a permit when the property was vacant and if you call him on it and it needs to be moved, he may be on the hook to get it redone and get it permitted. I would make every effort not to be a dick, but at the same time you gotta be careful in case you accidentally cut his power or something like that and you have him permission or whatever there may be some liability on your part.
It sucks being in a shitty situation with a neighbour and a feud develops so avoiding that is never bad, but you absolutely want to make sure your ass is covered.
I believe there's virtually zero setbacks in the Midnapore neighbourhood. I was helping someone house hunt in there and a few of the houses literally had their foundation at the property line and their eaves over the line.This quote is hidden because you are ignoring this member. Show Quote
It was crazy.
Utopia.This quote is hidden because you are ignoring this member. Show Quote
My buddy just bought a place there, but being a townhouse this problem was implied.
Just short it out. Quickly splice in, run conduit to your garage and consider it a done deal.
Bonus if it's 240v.
It looked awful iMO...This quote is hidden because you are ignoring this member. Show Quote
I'm open to being wrong about the exact details or the name of the hood, but I think that's what the realtor told us. I don't understand how or why this could be when it's within CoC.
