26x27 garage build. - Page 3 - Beyond.ca - Car Forums
Page 3 of 9 FirstFirst ... 2 3 4 ... LastLast
Results 41 to 60 of 173
Thread: 26x27 garage build.
    BoostLand
    something green
    On the rebar, in my garage floor, they pounded rods into the compacted base and suspended the rebar lattice above the base about 3", the floor is 5" thick. I can't say enough about maximizing the available R-value available. I optioned for the highest R value the building could hold, my actual heat requirements are less than half of what was originally calculated. It was supposed to need 160k btu on the coldest of days, but one 80k btu/hr tube heater does it with ease. I would also take the wall to maximum height with a high lift door option.
    Edit: the liftmaster remotes suck balls, short transmit distance,but the buttons are too easy depressed when in your pocket. My old opener needed a solid push to "click" the button, the liftmaster swithes activate with little pressure so the door starts doing things if you lean against something or bend down.
    Too loud for Aspen
    Quote Originally Posted by arcticcat522 View Post
    I did remove 4 large trees prior to them coming in.
    HUGE thank you Sir! I was the recipient of some of those trees you cut down . Will hopefully be turning it into firewood shortly. It was a pleasure to meet you and the family and best of luck with your build. Looks great so far!
    Cheers,
    Rob
    Jan 2017
    Summer car or work truck
    Quote Originally Posted by blueToy View Post
    Cheers,
    Rob
    You are welcome. Good meeting you too
    calgary ab
    4x4
    Quote Originally Posted by Maxt View Post
    I think it was the MyQ repeater kit - that you could use; got you back onto the old 9series transmitter frequency/rolling codes. In most cases people were pretty happy with the range of them. There were a few areas where there were struggles for range though - up top of signal hill / above COP if I recall was a recurring issue.
    Jan 2017
    Concrete was poured yesterday in the blazing heat. I have been told because of that, the top in some areas has dired too fast and will crack/come apart. Looking at it, I see a couple spots where you can tell this will happen. How are they going to fix this? I don't think it's too big of deal for me since I plan on epoxy coating it net year. I will continue to spray it with water throughout the day. What should I know about the above.
    You ded. Rip cat.
    Feb 2006
    79 Country Squire 95 Deville 09 Jeep JK
    So did the concrete contractor raise the rebar? Did you address it with them?
    Inquiring minds and all....
    Jan 2017
    I asked for them to. They didn't want to. Said they can't wheel over when its raised. I did raise it with prices of broken up patio slabs. Only about 2 inches. Wanted to go higher, but it wasn't very stable higher than 2 while walking on it.
    When mine got done, I had a concrete guru professor say that covering it with burlap and keeping it wet for a few days was the key.
    I put the cheapest poly I could find on it after soaking it to help stop the top of the slab from baking too quickly in the heat over the first few days.
    The concrete installer said I was a complete fucking idiot and since he's the second dumbest person I've met on earth, I felt confident that I was onto something.
    Feb 2003
    DT 780
    LEXUS LX470
    That's brutal. Fuck those guys.
    Tap, Rack, BANG!
    Unemployment Line
    Sierra, RDX
    Soaked filter cloth and poly, or just poly at the minimum, should have been placed on top and kept wet for a few days, even without the heat that we had the last few days. Good on you for doing the lifting of the rebar despite their moaning, I would have told them to lay some boards over the rebar if they can’t place concrete in a form that’s been properly prepared
    Mind sharing name on contractor so everyone knows who to avoid…
    BoostLand
    something green
    On slab of that size, that's a pretty lame excuse. They wheel barrowed mine in over rebar on planks.
    Too loud for Aspen
    Jan 2017
    The builder has been really good so far. His concrete contractor, not so much. The builder calls every day to touch base and see if I have questions and has been very open to feedback.
    Jan 2017
    Framing has started and will most likely finish tomorrow.
Size:  225.9 KBName:  20210708_212731.jpg
Size:  241.8 KBName:  20210708_212521_copy_1210x2681.jpg
    Looks bigger with walls. Not big enough, but bigger
    You didn't use OSB for sheathing??! Did you fly that plywood in on your G6?
    I think my framer didn't put any of that up until the trusses were up. But that's probably just because he learned it from a different prison.
    Jan 2017
    2x6 on 16" centers too.....$$$$$$
  18. #58
    Jan 2017
    Roof up. Whooooo
Size:  106.8 KBName:  20210709_105615.jpg
Size:  265.4 KBName:  20210709_105629.jpg
  19. #59
    Spray Foam, or else you're poor!
  20. #60
    Jan 2017
    Spray foam the roof. Not the walls.....still poor. Especially after this garage.
  1. Pre build or build out a pc? Need to upgrade my home desktop
    By cycosis in forum Computer Help Desk
    Latest Threads: 02-28-2020, 01:16 PM
  2. Replies: 87
  3. My garage build
    By Rat Fink in forum Home and Garden
    Latest Threads: 02-07-2015, 10:16 AM
  4. Cost to build a garage?
    By M.alex in forum Home and Garden
    Latest Threads: 05-23-2013, 08:09 PM
  5. cost to build a garage (post-boom)
    By TimG in forum Home and Garden
    Latest Threads: 06-03-2009, 08:10 AM
