Electric garage heater - Beyond.ca - Car Forums
Page 1 of 3 1 2 ... LastLast
Results 1 to 20 of 43
Thread: Electric garage heater
    Dec 2005
    not calgary
    changes every year
    Default Electric garage heater
    So there is no gas run out to my shop. I'm looking to use an electric heater that can just be on low all the time, just to keep it from freezing in there when im not in there.
    How many watts should I look for? Shop is 15x22. What do you guys use?
    You have 240V out there?
    Probably going to be an expensive prospect unless it’s insulated.
    Dec 2005
    not calgary
    changes every year
    Ya its 240 and insulated
    https://www.homedepot.ca/product/ste...ter/1001644875
    I’ve always thought one of these “spider” style heaters Would be interesting.
    Aug 2011
    Strathmore
    2005 Dirtymax
    Quote Originally Posted by 03ozwhip View Post
    I was going to pick up something like this https://www.canadiantire.ca/en/pdp/m...5120p.html#srp to use in my shop.
    I use a propane heater right now but we know how good those are.
    You don't need to spend more than $150.
    I have something like this one:
    https://www.homehardware.ca/en/240-v...ater/p/5571917
    My only complaint was once last year, its thermostat got confused and it wasted a pile of electricity heating it up to 22°C when it was only supposed to be ~14°
    Aug 2011
    Strathmore
    2005 Dirtymax
    What is the loudness on those like?
    Ummm... It's louder than a fan but not by a whole lot. You can easily talk on the phone while it cycles on.
    To OP:
    You know that when you say "leave it on low all the time" that it doesn't work that way, right? It's either on or off and seeing a lower temp just means it cycles on less frequently and for shorter durations.
    Apr 2010
    Edmonton
    Skyline
    Just installed this exact unit in a insulated 22x24. Heats up fast and isn't loud at all.
    Oct 2006
    Parked in Baygirl's garage.
    '21 F150 PowerBoost
    This is all I use in my garage. Makes it comfy to be in there pretty quick.
    Boosted life tip #329
    Girlfriends cost money
    Turbos cost money
    Both make whining noises
    Make the smart choice.
    Originally posted by Mibz
    Aug 2011
    Strathmore
    2005 Dirtymax
    I would have preferred to pick up the one from Canadian Tire but figured I would try out a contractor one first. Swung by Princess Auto and grabbed this one.
    https://www.princessauto.com/en/4800...t/PA0008993263
    6.7 CUMMINS, E50 AMG
    I say go with a couple honeywell oil filled heaters
    Wow, that's cheap! I think you'll find that to be more than adequate.
    Sep 2005
    $179 at Princess Auto.
    https://www.princessauto.com/en/7500...t/PA0008944829
    I've had this exact same one in a double garage once and it heated the garage to 20C in no time when it was -15C outside.
    Jun 2005
    51N, 114W
    has 3rd party insurance
    make sure you check the wire gauge also
    Cochrane, AB
    Trucks
    Quote Originally Posted by tha_bandit View Post
    Why? The cord heat and wall outlet fire heat will only help. Have to keep an eye on the final result.
    Dec 2005
    not calgary
    changes every year
    Thanks guys, good suggestions.
    Quote Originally Posted by legendboy View Post
    If you don't have 240v, this is pretty reasonable, although slow because they use natural convection. Each one is 1500w if my memory serves. 3000w would keep garage steady state I suspect. Would take a lot of hours to heat if it's cold soaked to minus 20 though.
    Aug 2011
    Strathmore
    2005 Dirtymax
    Yeah my shop is like 22x28 all lacking insulation and vaulted ceilings. I would like a permanent heater but not worth the costs yet so a smaller focused will work better for me.
    Hybrid
    Wouldn't something like this be better for that application?
    https://www.princessauto.com/en/1500...t/PA0008944787
  1. Block Heater vs. Coolant Heater
    By hockeybronx in forum Mechanical
    Latest Threads: 11-12-2012, 05:15 PM
  2. electric water heater questions
    By thager in forum Home and Garden
    Latest Threads: 09-17-2012, 08:01 AM
  3. W.T.B. Electric Heater and Mini Fridge
    By SteveMo600 in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 09-10-2008, 04:28 AM
  4. FS: 240v Electric Garage Heater
    By legendboy in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 01-10-2008, 11:30 AM
  5. FS: Hard Core Garage Heater
    By MintRacer in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 08-01-2005, 09:29 PM
